What rate do most people consider to be a reasonable charge rate for their Lithium batteries ie a typical 18650 …. is 1C generally considered a level that will charge in a reasonably short time but without damaging the battery.
In essence I guess what I’m trying to ask is if I charge a 3000 mah at 1 amp am I doing it more damage than charging it at 1/2 amp or would you crank it up to 2 amps if your charger can do it???
I prefer 0.25-0.5C at most.
Makes the cell last longer, heats up less, etc.
Do remember that charge rate is only part of li ion cell lifetime, temps the cells are stored/operated at and charge percentage are big factors. Try to keep your cells at 10-20C, and moderate humidity
Li ion likes 40-80% best, so unlike some chemistries charging and leaving charged till you need it is a bad idea. I keep 3 batteries fully charged for everyday use (the sacrificial ones as i think of them), the rest are stored at 50%ish charge, and recharged when needed. I also store them in a airtight containers in a controlled humidity basement.
