What is the best and most accurate light meter for measuring our LED flashlights? Sekonics are known to be great but they don’t give a Lux measurement.
Depends how much you want to spend.
Can you show me some options? I’m willing to spend.
Djozz uses a calibrated MobiLux Class A luxmeter as reference for his tests
About $1.5k: https://www.lichtconsult.nl/product/mobilux/
A very low cost option is your cell phone.
CPU-Z can tell you what brightness the light sensor is reading. There may even be apps that can read and record numbers for you.
here is a turnkey solution for measuring flashlight output in lumens…
Texas_Ace BLF Calibrated Lumen tube / Sphere No math skills needed
the calculation of Lux has additional factors, that include distance, and illuminated area (beam shape):
for example:
both lights produce the same lumens, but the LUX are different because the light is spread over different size areas.
more info:
How to measure light in foot-candles, lumens and lux
and here is a Spectrometer
if you get interested in measuring Quality of light, in addition to Quantity of light.
Something relatively accurate and under say $300 would be good.
$175 – 3.5” version
contact Texas_Ace
Look at the second link I posted, DJoz tested the Extech LT45 and it was pretty good.
Slightly over $300 though.
You do know that a luxmeter and an integrating sphere/ lumen tube are not the same thing, right?
OP is talking about a luxmeter. For measuring lux. Not lumens.
But the kit comes with a tested Lux meter which can be removed and can be used to measure both. So more value for the dollar.
If you want to do runtime graphs as well, you can have a look here:
https://budgetlightforum.com/t/-/56270
And if you like putting together some tools yourself, have a look at GChart's Lux Meter project: https://budgetlightforum.com/t/-/56270/55
I'm using 2 Extech SDL400 for runtime graphs. They are about $300. They can do both, runtime and just lux measurements.
If you want to go that route, I would suggest getting a sphere rather than a tube for more consistent readings.
