There’s nothing I can do about it, but I admit I’m pissed about BS releasing a newer version within 30 friggin’ days! My seller says he was surprised too. I didn’t even get a good price! Oh, well, that’s what I get for jumping the gun. It’s still a great light.
Anyone encounter this?
I suspect my BS Terminator is driven too hard, she can’t be switched on for more than 10 minutes on HIGH. Temperature rise to very high, it hurts a bit when touch on the biggest piece of heatsink. She will cut itself off, the GREED led is off when she cut off, and button is not working. I have to unlock and lock her back to make the GREEN led to on again, then I can switch her on again. But in less than 1 minutes on HIGH, she will cut off itself again as temperature is still to high. Now I can only suspect it is the temperature as the same batteries work fine when temperature is low.
I am quite sure she is driven hard enough, thinking BS should put bigger heatsink for her.
I will not hesitate to buy this light again if BS release U3 version. Such a nice light. I think she is a thrower + flooder.
see review linked in this post Black Shadow Terminator just arrived. First Impressions before a full review.
I don’t see it mention cut off.
8.85A at 4.0V xml driver drops it 3.1V ( Typical forward voltage for XML.) 8.85x4.0=35.4W
35.4- driver 88%=31.12W : 3.1V=10.05A : 4= 2.51A per led. is that right or wrong?
Your calculations do sound right to me. The only thing that could be questioned is the 8.85A.
I use only texaspyro`s numbers but i get my own in couple days. I will do some test then.
Parasitic drain is 4.5 mA. Will run down most batteries in about 60-90 days if left on. Unscrew the body a bit to turn it off.
Now I have a new terminator. I did some tests.
Tailcap 8.2A with new batteries.
4.2v x 8.2A= 34.4W
i measured voltage from led. 3.1V
34.4W/3.1V=11.1A 12% driver loss =9.77A
9.77A/4led=2.44A each. can’t find U3 data
U2 led 2.44A= 800+lumen per emitter
4X U2 led =3200 emitter lumen
4X U3 led =?? tell me
I would be glad if someone would also make current measurements can be compared to my measurements.
very good flashlight.
minor disappointment was when I measured after use 3.8V and get only 5.7A
I hope you understand my bad English :zipper_mouth_face:
Figure a U3 averages 7% better than a U2. Also figure that the optics are less than 75% efficient. 3200x1.07*0.75… OTF lumens would be around 2600.
4.2v x 8.2A= 34.4W
4X U3 led =?? tell meI would be glad if someone would also make current measurements can be compared to my measurements.
very good flashlight.minor disappointment was when I measured after use 3.8V and get only 5.7A
4.2v x 8.2A, I thought it won’t be 4.2v under high current.
4.2v x 8.2A= 34.4W
—34.4W/3.1V=11.1A 12% driver loss =9.77A
4X U3 led =?? tell me—I would be glad if someone would also make current measurements can be compared to my measurements.
I removed wire from the led and measure current
3.1V 2.74A*4 there is no 12% driver loss. it is lot smaller.
New emitter lumens= 3600 - U2 bin and 3850- U3 bin
Loving mine! Big thanks to R&R, very much appreciated!!!
