I decided to revisit this and do some actual tests from a freshly charged battery.
So, after freshly charging a Samsung INR18650-30Q (4.20v), I placed it in the flashlights that use BLF A6 driver and do batt-check:
- on the Astrolux S1, batt-check does blink 5 times, so singularity35 is correct: immediately after a fresh charge, it could indeed read 5 blinks.
- on the Astrolux C8, batt-check also blinks 5 times
- on the Astrolux S41S (quad-Nichia 219B) w/ 18650 tube, batt-check only blinks 4 times (maybe because it has a higher current drain, and had to go moonlight~~turbo~~>strobe before reaching batt-check mode, so maybe that drained the battery slightly enough to register 4 blinks?)
I haven’t tried to determine at what voltage the Astrolux S1 starts to blink 4 times though…
The Astrolux S2 batt-check (voltage count) is over-counting as always — 4.20v will blink out 4.4v (I remember ToyKeeper mentioning this bug for the BLF X5/X6v2 driver which didn’t seem to get fixed in the production drivers, over-counting by 0.2v usually, sometimes by 0.1v).
Also, I did another test, I’ve had a generic single-slot charger that came with generic XML-T6 flashlight, which I’ve not used since I read they tend to overcharge (I used them before, maybe a couple of times only on the junk batteries that came with that generic flashlight). But I decided to find out once and for all, how much do they really overcharge? (following the recent experience with a severely overcharged INR18650-30Q of 4.48v — I had thought before that the 18650 might explode when seriously overcharged — but the recent experience didn’t, so I guess I’ll just try)
So, I put some junk battery on the single-slot generic charger and charged the battery, when it turned green, I removed the battery immediately and checked the voltage to be 4.28v (so it really overcharges). I placed the battery in the Astrolux S2 to see if it would blink out any different. The Astrolux S2 blinks out 4.4v with this 4.28v 18650. BUT there is a difference: after it blinks out 4.4v, it subsequently blinks 3 times (actually 3 blinks with short pauses in between the 3 blinks, then a longer pause, then repeats). I think this might signify as a “battery error” condition (too high voltage) for the BLF X5/X6v2 driver?
