You have to upload photos first over at some free image host like postimage.org, then grab a link (ends with .jpg) and paste it here in the Image URL field…
Yes your right the reflector extends inside the centering ring it pretty much touchs the led now I’m looking at it. I’m thinking its this design the really makes the light. I could be wrong but it seems to give the throw a more even appearance. If you look at certain beamshots of the BLFs giga light you can see at a close up there is a slight gap in the beam. Not sure how else to describe it still having issues attaching pics but I bet if you were to extend the lens past the centering ring like the TN-42 it would give the beam a slightly better balance. Not sure if that makes sense or not.
Every light with an LED and a reflector has this “gap”. It’s normal. The more focussed the light is (how big the reflector is compared to the LED die), the farther the distance until this “gap” disappears. The BLF GT is the most foccused led reflector light ever produced until now. People are not used to this effect.
Check out this light. It has a very similar sized reflector but an even smaller LED. The “gap” is even more pronounced.
Looks very impressive. At first I didn’t like the ramp either but now you guys say theres different modes around it That makes the light more impressive that when you want a ramp it’s there otherwise couple clicks and its got a step up. I had a big 3,000,000 candle power halogen spotlight with a slight ramp and that thing was a beast. I lived on a lake and could shine it across the lake. So bright I went out at night and could actually turn off streetlights. Thats how amazing this thing was. I’ve been waiting for something more compact that could out perform. Finally I think this light might be the winner. The big hologen bulb got hot and the batteries lasted about 30 mins had to have a gass lens that added weight. Good for quick spotting animals. But this is a whole new thing. Where can I put the $14 down for it so I can get in the group buy? Think it will be released as early as February?
Those “3.000.000 candlepower” halogen spotlights don’t go above 400.000cd in reality and are also not regulated (they get dimmer as the battery depletes). You are in for a big, bright suprise ;).
Yeah which was like after 5 mins Lmfao and it took probably an hour or two to charge and was heavy! Years back I switched to a Maglight 4-D then later bought a 6-D thought that was impressive and amazed everyone at the campgrounds with how “bright” it was. I like thrower lights because you could light the tops of trees and if you wanna pick out animals like bears and moose from a distance at night you can. Now its gotten to the point where a $7 grocery store flashlight is brighter then a 4-D. So I really can not wait to get into the group buy for this thing. I think its about time and at that price compared to everything else is even more the reason to go for it.
1) the TN42 does not use a dedomed LED, it uses an XHP35 HI which has a flat layer of silicone instead of a domed layer of silicone.
2) the TN42 does not have anything around the LED except a circle of silicone which is used for centering.
3) what you are thinking about is this:
Some flashlights flatten the bottom of the reflector to use it sort of as a centering ring to save cost.
The reflective part at the bottom literally does NOTHING to the throw or beam of the flashlight, because the LED does not emit light at those angles.
If you look at the flashlight from the front, none of this area looks yellow because it is not reflecting any of the LED.
The only area that is yellow is the usable surface of the reflector which is a parabola.
Any part of the reflector which is not a parabola (such as the flattened part at the bottom) does not reflect any light from the LED into the beam.
4) there is no “two beams” of light from any flashlight.
If you are talking about this image posted a while ago, it only looks like “two beams” because that is what a hollow cylinder looks like when viewed from the side.
The walls of the cylinder have the most flux in them due to the emission pattern of an LED.
It is a cylinder of light, not two separate beams.
This is the case for ALL flashlights, but the larger the reflector is, the more visible it becomes.
Yeah I’m still around, shocked to realize that I’ve actually been into this hobby for quite a number of years already (and spent A LOT), but I am not as active as before anymore due to my hectic work and also some changes in life priority.
Mind to share what’s your new hobby? :laughing:
I bought some batteries from Gearbest too but I seldom use my lights nowadays, but it’s true that Gearbest rocks nowadays by being able to ship batteries, and ship them fast!
Thousands of BLF members probably went through this admittedly logical reasoning and held their horses. On a flashlight enthusiast forum.
Many of them spent hundreds on tacticool knives they will never need for more than a $11 Opinel would accomplish(almost guilty of that myself).
Even more spent thousands on firearm hobbyist stuff, even body armor, they’re never going to need outside of their backyard operator life because they’re obese with back problems and not going to be battlefield worthy should their wildest zombie apocalypse fears realize(definitely guilty on that one).
Too many spent or are going to spend all their disposable income on a nice car or truck. Probably not really that nice, but one that once was in a teenage fantasy.
Probably more than that have spent or will spend or have been enslaved for the rest of their lives for a nice house they never really liked and will lose by divorce theft. Be it $100k, $2M or whatever suits their location, local expenses and income level, many will have done just that. More will follow no matter how much the more experienced try to warn them.
Meanwhile, spending more than $100 on a legendary handheld gigathrower sounds like a lot. Hey, it must be stupid so let’s not do it. All of this on a flashlight enthusiast forum. Go figure.
Those active users of this forum who are also effectively involved in any kind of business IRL waste more of their time worth in money in a week just browsing the forum than the GT is worth. Why not just not read the BLF for a week and compensate afterwards by buying the GT?
