BLF Kronos X6/X5 GB - Group Buy now closed.
well my boxed set arrived yesterday and i never got to see it because it was apparently stolen off my front porch
Absolutely!!!!
Ken, use a sandal or a tennis shoe… a deck shoe for wearing on a boat like a Sperry Topsider is ideal… press the open face of the reflector against this rubber to grip it, twist the head of the light. Should unscrew. Or lay the piece of rubber down so you can press the light down onto it and twist off.
Obviously, make sure there are no little rocks or pebbles stuck in the tread of the rubber before you try this. :wink:
My lights showed up monday, #042 of 400.
The box had dents and chips in 3 of 4 corners but not too noticeable.
I ordered the 3B emitters and the X6 was 3B but the X5 is 1A.
I would have ordered that combo if I could have so that’s fine too.
In all a great deal, I’m really happy with this group buy.
Thanks for all the effort. :slight_smile:
You do understand that I have NO issues with the SS/Cu set. The issue I have is with the Al X6. So stop talking about the SS/Cu set.
I’m not out for refund each time a have an issue. But I MUST be allowed to write about my issues like all others in this thread. Don’t know why I is so unlycky with stuff like this, but I had no issues with the 7 BLF A6 lights, or the 4 BLF D80 lights I got. Also got several EE X6 XP-L HI without any issues, and a ton (around 30) of S2+ from Simon and Gearbest, all working 100%.
Still, why do you hate me so much? It is not me that have make this light, it’s not me that has glued or tighten the reflector and it’s not me that have made the yellow spot. But you blame me for it it seems.
So I’m not allowed to complain when something is wrong? The Al lights is public, so I can buy so many as I want, still, issues is issues.
Replacement parts won’t fix this.
A screwdriver and some fine-tuning and possibly a strap wrench will fix this.
Possibly a thin spacer too, like the one RMM at MtnElectronics carries (linked a couple pages ago), or a few sheets of paper cut to fit (or whatever else you can wedge in to keep the reflector from going too deep).
The issue here is that the reflector is stuck, so I can not open it to fix it. That is the main issue. If I could get the reflector open, maybe there would be a easy fix for the issue.
A couple people have mentioned that. I wonder if there was more than one batch made, with slightly different processes. Or maybe more than one chunk of copper used as source material. Got a picture? I’ve never actually seen a copper mismatch.
Ugh I’m sorry man that’s just awful. People make me sick sometimes I swear. Hopefully karma will catch up to them.
MY mistake thinking it was the SS/Cu set but my position still stands.
Ken, you need to learn more....just fact of it. You look for the tiniest fault in everything and that is not what this place is (at least in my opinion). This place takes great pride in taking nothing and making something. With these group buys we do our best to make that possible for everyone with no effort AND at a cost less than what one could do for the cost of parts alone.
The yellow may or may not go away...I do not know because it IS not uncommon BUT once you mentioned "Contact Neal" all bets are off in my book. If you can make it go away ...great...if not, then just sell them...you are after-all in the flashlight reselling business.
Arrival! 8 total days with that free Priority Direct shipping, can’t beat that. I got them about 1:00. Wanted to go for a bike ride. Didn’t open the package at all, how many could do that? Came home from the ride and opened it, first the S.S. OH MY GOODNESS! Not a mark on it. People weren’t lying when they said these were HEAVY! I got 2 clips with mine, both in the bag. The light/UI works great. Thanks to Dale’s config. video posted earlier it was simple. Haven’t attempted changing the number of modes yet however… I’m giddy over these. Should have bought more sets :bigsmile: Will definitely have to get an aluminum set as well, as these will be shelf Queens. The lit tailcaps are nice but can’t get used to them. Not going back to find a post but this lit tailcap doesn’t draw too much power? No worries? I don’t want to have to keep unscrewing the tailcap to turn it off. And then there is fear of GALLING :wink: Whatever.
The copper one is awesome as well. Great lil size. After seeing some pics it would be nice to have an amber or red tail light in this one. The clip came on the copper light. How do I get it off without scratching the body?
These two lights are amazing. Sorry for the others, but mine do not have a mark on them. I did not get the box. I think TK said the S.S. put out 1400 lumens stock. How about the copper one? Did I hear 1300?
I couldn’t be happier with these. I’ll just keep these 2 and get rid of my other 70 lights! Wait, I’m keeping the A6 too. The wait was worth it. No way to show my gratitude. Here’s a couple of pictures:
I got my set #021/400. Here are my first impressions.
  1. The lights are heavy!
  2. Some of the corners of box are a little dinged from shipping, but only noticeable upon close inspection.
  3. The bottom felt is worn through because of the weight of the lights and movement during shipping.
  4. The black foam insert smells. I am concerned about deterioration over time. Who knows how the outgassing will affect the metals.
  5. The X5 can tailstand when off but is wobbly when on. The X5 is wobbly when off and won’t tailstand when on.
  6. Both emitters are not exactly centered.
  7. Other than tiny issues above, the build quality is excellent.
My plan is to shave some rubber from the tail caps and investigate replacing the foam insert.
Edit: I shaved 1mm from the X5 tail cap and it is stable tail-standing.
Thats because I ordered cheap (type Ultrafire and Cree) lights, that’s promised the world, and was just crap. The last 6 months or so, I have only got Convoy S2+ (30 pcs) and Convoy C8 AK47 (10 pcs) lights from Simon, each specially modified (and Gearbest), Eagle Eye X6 XP-L HI (6 pcs) from a producer that made a small batch, then I have been on three Group Buys here, actually 4. BLF A6 (got 7), BLF D80 (got 4), 4 x BLF-348 - Classy and Small 1xAAA Stainless Steel light and now the BLF X6 SS/Cu and Al GB. Also got some JM35, Yezl y3 and a Nitecore MH20 (it was expensive)
I have learned from my mistake, and would say that I only buy premium lights now, since the GBs provides premium lights. If they don’t do that, and people still think I buy crap, why do we have the GBs then?
But still, this time I was unlucky with ONE Al X5 light of all the lights mention over
Uncommon, yes, but not for lacking of trying to get premium lights without the knowledge to build one my self.
Thats little of my point. You use so much time to create the “perfect” light, for a good price. You work for months. Then, when I buy a such light, I have higher exception to that light then to a $2 Ultrafire light on Ebay. I must be the most unlucky person on this planet, for what is the change that I get a slightly “damaged” light from this great GB?
Stop taking it so personal. I love the work you and the rest of the team have done. Love the SS/Cu set, love the taillight, love the UI, you have done a hell of a job. But some Chinese person has not done a good job on this Al X6, no QC. That’s not your or the teams fault, but the producer.
Neal is selling thees lights, and if any, he can fix this issue with my light.
So, no personal to you or the team (despite you are very personal with me).
… this makes me sad too.
Blasphemy!
Maybe TK can activate the remote GPS locator for you.
Seriously, that sucks. I hope they drop the X6 on their toe.
Not just crap I have now…
To restate an earlier thought in a different way…
Thanks for thinking of us organizers, southland. Defending us, fighting for us. Skirmishing with the nay-sayers. The thought is appreciated. Warm fuzzies all around. :slight_smile:
However, I kind of agree with Brett… for one simple reason. I knew what I was getting into when I signed up for this.
I can handle the flames myself.
I feel your pain. That sucks the big one.
I stopped my mail for the week so I could pick it up from the PO. Also just installed a locking mailbox since mail theft is rampant in some areas now.
Ken, try a latex swim cap or non slip mat laid flat on a table. Use that to grip the reflector and twist the head. Try it at different temperatures. Don’t get defensive, just don’t respond to those posts. That’s a large part of your current reputation. Practice on me.
