… and with the new firmware, I have some questions I’d like feedback about.
1.
The main thing is… having 7 or 8 (or 8-9) normal output levels might be a bit much. Does anyone really want more than the default moon plus six?
If nobody wants 7/8 (or 8/9) modes, those two mode groups could be used for other things.
For example, mode group 2 is: low, max. So, like, 10 lumens and ~1300 lumens. Nothing in-between. Perhaps there could be another 2-mode group which is more like 130 lumens and 1300. Or maybe a popular config which goes 130, 1300, strobe? (not a hidden strobe, but actually in the main loop)
Mode groups 7 and 8 could potentially be used in different ways, so how do you think they should be used?
No change: 7 (and 8 ) evenly-spaced modes from low to max.
130 / 1300 / strobe… plus maybe an alternate version of some other mode group. Like maybe low-med-max-battcheck?
… other?
2.
Additionally, how bright should the lowest non-moon mode be? The A6 started at about 10 lumens, but the tighter throw in this makes lower modes look brighter. The lowest mode will be the starting point for mode groups 2 through 6 (and maybe 7 and 8 too). Should it be 10 lumens like the A6, only with much higher lux (same output but looks brighter), or should it start lower to save power and keep the apparent brightness more like the A6 used?
3.
Finally, which config options do you think you would want to change most often, so they can show up earlier in the menu? The current order is:
Muggle mode toggle.
Mode memory toggle.
Moon toggle.
Mode order toggle.
Choose a mode group (how many levels).
Medium-press toggle.
Thermal calibration mode.
Factory reset.
Options which get changed only once should be toward the end, while options you might want to change more often are toward the beginning. Is this a good order for the options?
The host material makes no difference to the behavior of the driver and tailcap, except for the ability to lock it out without removing the cell. I’m basically proposing a way to achieve the following all at once:
More appropriate tail brightness level.
Minimize change in button timings when a lighted or non-lighted tail is used, so you can swap tails without issues.
FWIW, muggle mode probably needs to be first in order to make the other options inaccessible while in that mode. Also, it’s the closest option to the A6’s first option (but it goes to/from 3 levels instead of 4 levels).
After that, it’s a question of how often you’re likely to use each one. Like, I turn memory on and off somewhat regularly (if I want to start in strobe next time, or check several cell voltages) but it’s rare that I want to change how many total modes there are.
So, it’s already about as close as it can get to how the A6 works. The A6 had a switch between two config “bundles”, then a memory toggle… and so does bistro.
Please krono and Neal, make it so we can buy some little alu X5’s either as a host or a complete light.
Because i have no use for the SS/Cu + Cu light combo or another alu X6 in non triple config.
But i can see myself buying plenty of little alu X5’s if they where available
I think this is best option, rather than remove and add resistor. Remove it probably not that hard but if change mind and want to put the resistor again will be harder.
Please make it as default, saving some cost and less work too.
Except that the long press (1-1/2 seconds) becomes a reallly long press (2-1/2 seconds) for the default lighted tailcap that will come with the flashlights.
And if I wanted the long press back at 1-1/2 seconds, I would have to replace the tailcap assembly with a plain one (if an entire assembly were available) or replace the lit tailcap switch with a plain tailcap switch.
Thanks dudunphy! i thought pilotdog was talking about another price configuration, maybe for the Al X5 by itself
well, i am quite new to all this - so will have to spend some time learning about this 25 thing. thanks for pointing me in the right direction to get started.
The firmware can only have one calibration shared for both tailcap configurations, unless I remove something else to make room. That means that one config would either have a longer “long press” (and easier window for “medium press”) or a shorter window for “medium press” (and a quicker “long press”). The first option seems less annoying.
Besides, lots of commercial lights require significantly longer for a “long” press. Like 5 seconds or even 20 seconds. Having it at 2.5 or 3.0s isn’t so bad.
1. Moon plus 6 is okay with me. I really don’t see the advantage to splitting hairs any further than that.
2. 10 lumens is good. I see these flashlights as being more “mini-throwers” than EDC’s. Otherwise, if I were using them as a daily EDC, I would like the next level above moonlight to start at 5 lumens.
3. The option order is fine with me. I don’t shuffle around very much with my BLF A6, so I don’t think I’ll be changing options very often with the subject flashlights.
1. I’m perfectly happy with the original software mode layout. I could even do with one or two less personally, but the moonlight is fine (could even be dimmer, but no brighter.) One day, in a perfect world I’d love some fireflys like a Zebra or Armytek, but I know it’s hard to do. But basically whatever you decide is fine, but it was good as is.
2. I like your idea about making it a bit dimmer. It seems most of the complaints about lights are the low end spacings, especially headlamps. I think you could change mode 2 to under 10 and then make Mode 3 a bit lower too… to like 40ish.
3. Since I want to keep moon, and memory, and don’t have interest in any of the other features except maybe factory or thermal it doesn’t much matter to me.
Again also… the switch. Can you put in a dumb switch or not? And will it come with one?
Just an observation, but I’ve got two “factory” BLF A6 lights and a custom light I built around MtnElectronics version of the BLF FET+1. They’re clearly different boards, although I know the circuit is probably identical.
However, it does seem that the moonlight on the MtnElectronics driver is quite a bit lower. Anybody else noticed this? Or am I crazy? I haven’t measured it or anything and my custom light is quite a bit different than the A6 (triple XP-L), but the moonlight on it is crazy low.
I don’t have a comparison picture handy (although I should!), but here’s my triple FET+1 laying next to an SC62w on its 0.06 lm mode.
Maybe he’s doing something different that could be of interest to this project.
An idea for the lighted tailcap mod:
Instead of removing one or both resistors it could be possible to cut traces on the switch pcb at the right places. If you can find the place, there could be default breaking points changable with a solder bridge like the stars on some drivers.
