My D4 running Anduril is 2.1mA at the bottom of the ramp, with my Lexel aux board also. With just the aux board running, which is barely enough to navigate around my house at night, it is less than 1mA. At the bottom of my stepped range, its 4.7mA, which is super easy to see anywhere in my house. I use this when I want to illuminate a safe lock at my work. 60mA is ridiculous!!!
I donât know how bright you all want the switch/ auxiliary light to be, but does the cri even matter at a sublumen brightness level, since the human eye can only see b/w in very low light conditions?
For the switch âglow night lightâ CRI is not important at all. What is beneficial, is to keep it in the yellow/amber color spectrum as a night moon light/firefly glow in the range where it do not upset the circadian rhythm for sleep, while blue/green spectrum light radiation reduces natural melatonin production in your body.
The blue light melatonin thing can be misleading. A 2700K light at 100 lumens contains a lot more blue light than a blue button LED at 0.1 lumens. Even though it looks yellow, it has a bigger impact on sleep than a blue button.
For me, I leave on my 2000k Tiara Pro at maybe 20 lumens when I stay at hotels. Does not affect my sleep unlike cooler cct lights. My sleep quality is generally very sensitive to light. Perhaps a 2000k indicator light that can serve as a firefly night light might be nice.
Yuji makes SMD LEDs already, 5730 and 2835. The site throw 404s so I canât link to them directly. I have datasheets at hand - they go down to 2700K. But why Yuji? They donât seem any better than Optisolis to me. Am I missing something?
As to reasonable order quantitiesâŠ.I remember reading some guy who tried to get a batch of custom LEDs manufactured.
Minimum order quantities were in the millions. With one exception - Nichia.
I tried to find that post now (it was some blog I think) - and I failed. Thatâs sad, it was a nice read.
I misread the posts, I thought was discussed the main warm leds. Indeed, tweaking the CRI criteria of the LED of a switch is plain ĂŒberluxury, probably overengineering, and mainly unuseful to the enduser.
That said, at this state, what are the aimed official CRIs levels for the LT1?
I donât know where the idea that we are using some random aliexpress driver is coming from, but we are using a custom made driver desigend by Lexel. You can find pictures of that on the buttom of the main post on the first page.
All of those - 2835, 5730, Optisolis - are overkill for indicator lights - capable of significantly more output that is needed, and with a cost the manufacturer wonât be favorable toward. They might even be large enough to be a packaging challenge for a button PCB. The whole PCB is maybe 8-10mm across. After providing room for the button itself, a 2.8mm wide LED looks really big.
Worrying about 90 CRI vs 80 or perhaps even 70 CRI like we often do for primary emitters, Iâm sure is getting carried away.
Between a monochromatic or even phosphor-converted amber emitter, and a very warm white, Iâm not so sure, despite the low lumens.
My wife has several different types of electric âcandlesâ with some form of amber LED. Even the glow of the candle itself, not considering the illumination of nearby objects, looks non-candle-like to me.
Iâm not advocating one way or the other. Just suggesting I think there would be a visible difference between those options.
Cleaning up the formatting of the above, quite satisfactory response from the lantern guru himself for easier reading.
Also, to further clarify what I was getting at: I think a very warm (<2200K) white indicator of any CRI will have a different character than an orange/yellow/amber one, not that it is necessarily better suited for the purpose. Also, based on djozzâs post a ways up, this tangent might be moot anyways.
