That is a valid argument, but another valid argument: perhaps Sofirn went with so many extra features than originally projected because so many will be sold, keeping the price steady.
Well suppose it is around 50 bucks then I may buy two, would be worth it not having to worry about a conventional lantern globe breaking or mantles getting broken
With the advent of solar, this is an easy choice for me. I purchased the eceen that everyone recommended and I found that it works just as described. It was a bit refreshing considering I had purchased cheap alternatives before and none ever charged items effectively. This one was instantly working.
That suggests the lantern may be most efficient at 4000K, since it’ll be at full light output, but running both sets of LEDs at a lower power, more efficient level.
I’m going to be spending a lot of time playing with this thing
Since the final driver is based on a single channel of 7135’s for each set of LED’s, the forward current is the same regardless of ramp position. Although PWM lowers the average current, and therefore perceived brightness, the efficacy is primarily determined by current during the on phase of the PWM.
Increased temperature also reduces efficacy, but since the emitters are sharing an MCPCB, and running at the same total average current regardless of whether it is one bank at 100% or both banks at 50%, the temperature difference between the scenarios will be very small.
Maukka did a test with the Emisar D4 a while back that happens to be relevant. At max 7135, he measured almost exactly the same efficacy as at a level slightly over half the same output:
So I suggest not worrying about efficacy too much, and just choose the color temperature appropriate for the situation. With 4 cells, you will get a lot of runtime regardless of the tint.
Yeah, but you’re forgetting one simple thing. If all the emitters are sharing current equally, it will be more efficient than if only half of them are, whether or not there is PWM involved. IIRC, TK already said the light gets brighter in the middle of the ramping between CCT groups, so that pretty much confirms this. Then, TK tweaked the settings to reduce the current at the middle, in order to keep the brightness level the same throughout the CCT ramp. That means you will literally get the same amount of light for less current when sitting in the middle of the CCT ramp. I guess I could be remembering wrong, but I thought that’s what she said.
