Would it actually be better/easier to use protected cells here vs unprotected given the built-in features of the LT1? Just trying to figure out for the same purposes of potential gift giving…
As was discussed for the Q8 also, which uses the same battery configuration, in a 4xparallel configuration protected batteries do have a real advantage: no driver protects you from inserting one of the batteries the wrong way and upon closing the light frying the springs, or worse, from direct shorting the batteries against each other. It will happen at some point. Using protected batteries at least saves you from collapsing springs, that nasty resulting smell afterwards, and having to find and solder at least two new springs.
Since you said this, it made me curious. So, I just went and looked at his comparator with those two cells. I set the graph to show a 2A line and 3A line. I’d say that what you described above is dead on. The GA showed a tiny bit higher voltage, and the 35E showed a tiny bit more capacity. At those current levels, it is my opinion that splitting hairs would be an easier job than trying to choose a “winner” from those two cells. I don’t think I’ve ever seen cells from two different manufacturers “match” so closely!
2.5A total maximum. 7 0.35A linear driver chips, you can configure the light for less, likely it will come configured for less and you would need to configure it for the 7 drivers. Four of most any battery would work. One of most any battery would work, but for not as long.
my personal rough guess is September. That’s based on my guess that
DBSAR will get the final production sample in the next 2-3 weeks
he will test it for a week, and not find anything requiring a change for this model
and in 2-3 weeks Sofirn will have final units produced for sale.
But that is only my personal, not terribly educated, guess. I hope I’m wrong and its sooner, but its likely more of a best case scenario.
IN the picture all the drivers are enabled, so the pads next to the numbers 3-7 for both AMC NW and AMC WW are filled with solder. I don’t know how many of those will come filled with solder from the factory, but likely the numbers 3 and 4 for both AMC CW and AMC WW. Adding or removing solder will add or remove the number of drivers connected. It not necessary to do them in numerical order, as they are all in parallel.
Bottom line, you need a soldering iron or some other way to remove or add an electrical connection to small pads.
