DBSAR
(DBSAR)
9882
I am unsure of that, Sorfirn or Barry can answer that hopefully.
Kodrann
(Kodrann)
9883
Sorry if this is a dumb question but its the LT1 supposed to thermal throttle? I forgot to lock out mine and it turned on inside my backpack, after 2 hours when I picked up the bag I noticed it was warm⦠the head of the lantern was too hot to touch and the batteries and carrier were warm, even my L21a that was inside was warm too.
Maybe it was too much heat to handle? Should I calibrate the temp sensor? Again sorry if this is normal in a closed environment like a backpack, I really like the lantern and would be sad if it burns itself down lol
djozz
(djozz)
9884
There is no thermal regulation in the LT1.
At room temperature without cooling or air flow, the LT1 with all chips enabled eventually reaches 62 degrees Celsius on top which is hot but a very safe temperature.
In a closed environment like in a backpack, if switched on at full power, the LT1 will get much hotter of course, but as other flashlights, it probably can handle well over 100 degrees Celsius before damage occurs. Given that too hot to touch already starts at 55 degrees, there is quite a lot of headroom there before things really go wrong with the light. So your LT1 will probably be alright, but of course that can be different for the other stuff in your backpack.
Next time locking out your lantern may be a good idea?
Kodrann
(Kodrann)
9885
Understood Thanks for your answer!
Yeah will do! I have learned my lesson with my SP36 but since it is the first time I throw it in my backpack, I completely forgot to ā4Tapā
Unloco
(Unloco)
9886
+1
I still havenāt bought the first one.
I have the code but I prefer to wait for the orange version (at ebay).
saypat
(saypat)
9887
I havenāt purchased the first one either. Probably not going to. Not that it isnāt a great offering at a great price, it is, just that there are other lights I would prefer and CANāT BUY EM ALL!
bmg50
(bmg50)
9888
Is it too late to get a group buy code for Amazon? @sofirn
amishbill
(amishbill)
9889
You should PM that user directly. I donāt think the board is infected with ` automation.
wahoowad
(wahoowad)
9890
Sorry, searched and could not find the ādimensionsā of the lantern. I want it so I can shop for a cheap neoprene camera lens case to protect it. Anybody know the dimensions?
We need a LT1 wiki. Too much non-factual info (questions, tears, etc) in this thread and would be great to have a reference.
toobadorz
(toobadorz)
9891
Just found a tint ramp bug on my LT1. You may reproduce it as follows:
1. Reset to factory default (not really necessary, just to ensure a common beginning)
2. Enter the lowest brightness with the default stepped ramping.
3. Ramp the tint to the warmest or the coldest side.
4. Now stepped ramp to higher brightness levels, and youāll see it. If you chose to ramp the tint to the warmest side, now the tint gets cooler when the brightness is ramping up. If you chose to ramp the tint to the coldest side, now the tint gets warmer when the brightness is ramping up.
Not a bug, but a feature?
Iām unable to flash my LT1 because the programming holes donāt work as they should. I explained the programming issue here: BLF LT1 Runtime test *updated 12/11 with step level 2*
sbslider
(sbslider)
9892
It is not a firmware problem, it is the design. One can choose to have warm tint at low light, and cool tint at bright light, or the converse. That has been discussed in this thread previously.
regarding the programming pads,
Not sure what version of the programming key you have, but it appears some small mods need to be made to work with the LT1. I donāt know anything more than this regarding the key. I do know that connecting directly to the chip works fine.
spinynorman
(spinynorman)
9893
Itās supposed to do that.
sbslider
(sbslider)
9894
take it up with ToyKeeper if you like.
toobadorz
(toobadorz)
9895
Good. Thanks for the info. Itās almost impossible to follow ~9900 posts to learn this fact⦠:person_facepalming:
Of course Iām using the Lexel one, not the Emisar one. I own both, and I have confirmed that the pins on the Lexel one do match those holes on both ROT66G2 and LT1. However that just didnāt work. I donāt like to pull out the driver each time for a firmware upgrade.
I also soldered wires directly from those programming āholesā to the USBASP programmer. However it didnāt work either. So most likely those holes themselves are not working at all in the design circuit, or both my ROT66G2 and LT1 are defective units.
I did successfully reflash my Emisar D4S, D4V2, Fireflies E01, PL47G2. I suppose I know how to do this correctly with programming āholesā or āpadsā.
sbslider
(sbslider)
9896
I hear you.
Regarding the programming, maybe Lexel can help here then. I donāt know the order of the pads, but one could fairly easily figure out what pads go to which pins on the Attiny85, but it would require removing the board once.
Lexel did test a prototype board, and Iām almost certain ToyKeeper has reprogrammed the LT1 via the pads several times, as she provided me a few builds to test. Maybe she also knows if there is some specific wire swap that needs to be made.
Sorry I canāt help more, if/when you learn something please post it.
spinynorman
(spinynorman)
9898
The facepalm was for the ābugā comment, not the tint ramping feature.
BrianK
(BrianK)
9899
Iām fine with another one in black (better to hide it from the wife
), let others have what they want.
amishbill
(amishbill)
9900
I started a thread on LT1 Carry Cases to capture carry case information outside of this monster of a thread. Your dimensions are there.
joechina
(joechina)
9901
ToyKeeper:
Itās hard to say exactly, until the lantern gets measured by people who are equipped to do it accurately. The shape and beam pattern make it difficult to measure, so the specs are more āeducated guessesā than accurate measurements. Itād probably need a somewhat larger sphere than usual, ideally with a reference light to calibrate the sphere after the lantern is inserted, and potentially a reflective coating on the dark top section of the light. ā¦
For what is a reflective coating necessary?
I thought you can calculate the loss of the body by:
- use the empty sphere with the reference calibration light
- use the sphere with the off/dark lantern and the reference calibration light
- calculate how much light the lantern body absorbed
- then measure the brightness of the lantern
- use the calculated correction for the body.
(sorry if already answered, I am 300 posts or so behind)
