Does it continue to glow if you unscrew the battery tube from the head. That should eliminate if it is caused by some sort of an electrical leak causing the glow or something that glows without power.
I have a question... The answer has to be somewhere in the thread, but I can't seem to find it.
The LT1 lantern, by default is configured for 5x7135 (1.8Amps), but can be configured as 6x7135 or 7x7135 (max, ~2.5Amps), by soldering the joint points for each solder point on the driver board. I forgot whether it was also possible to reduce the max power (3x7135 or 4x7135), by desoldering the points marked "5" and "4"?
I notice on the rev 5.0 board, the "5" and "4" appear to be linked by electronic circuit trace.. so it means reducing the power is possible on the older batch but not as easy on the newer batch?
Well that sucks I ordered a 3rd batch lantern and type c to type c did not work. It would not surprise me if sofirn has sent me a earlier model as I feel they do not ship on a first come first serve basis
The driver on the right (the rev 5.0 one) has two resistors near its left edge, labelled R_CC1 and R_CC2. Those enable USB-C to USB-C charging. If your driver doesnât have those resistors, then youâve been sent an older version LT1.
Ok this is weird but apparently I do have a 5.0 version but it will only allow me to charge the lantern via my phone but it will not charge my phone. So in essence the type c to type c does work lol
Type c to type c charging does work on the 3rd batch LT1 Lantern I have it plugged in the powerbank now via type c output and im happy with the results!!!
Sorted. Thatâs the way itâs supposed to work. The LT1 is only designed to accept power from an external power source, so it can charge itself up. It canât provide power to another device.
One day, there might be an âLT1 Deluxeâ, with a powerbank function that can provide power to another device, but thatâs a long way away, if ever.
Thank you for confirming that the new LT1 does charge from a USB-C charger - now we know for sure that the rev 5.0 driver upgrade works as planned
Just ordered mine with the kit and the case. The description mentioned âlatest versionâ so hope to get the latest with usb-C to C charging. Will be my first lantern\soda can style light.
