Instead of creating new threads everytime this goes on sale, I decided to update an existing one. The previous one had a free Xanes laser for $48. This one doesn't have the laser for $1 less, which is good for those who don't care for the laser.
BLF Q8 4x XP-L 5000LM professionelle Mehrfachbedienung Verfahren super helle LED Sale - Banggood Deutschland sold out-arrival notice-arrival notice (Affiliate link)
Specification:
| Product name: | BLF Q8 4X XP-L 5000LM Professional Super Bright LED Flashlight |
| Brand: | BLF |
| Model: | Q8 |
| Emitter Type: | XP-L HD V6 3D |
| Light temperature: | 4750K-5000K |
| Light color: | Neutral White |
| Mode: | Smooth ramping or mode set operation |
| Material: | Aerospace grade aluminum alloy construction |
| Total Emitters: | 4x |
| Battery Configurations: | 4 x 18650 or unprotected button top (not included) |
| Working Voltage: | 3-4.2v |
| Switch Type: | Electronic switch |
| Switch Location: | Body side of the flashlight |
| Peak Beam Intensity: | 50,000+ cd |
| Impact Resistant | 1.2meters |
| Max Output: | 5000+ lumens |
| Range: | 450+ meters (max) |
| Lens: | High transmittance glass |
| Reflector: | Aluminum alloy mirror reflective cup |
| Waterproof: | IPX-8 waterproof |
| Color: | Black |
| Weight: | 400g without battery |
| Size: | 132mm x 59mm x 50mm(length x head x body diameter) |
Features:
• Compact and lightweight 5000 Lumens flashlight
• Utilizes four XP-L LEDs
• Uses four 18650 batteries for maximum runtime up to 1500hours
• Features advanced temperature regulation (ATR) technology
• Integrated power indicator in side switch indicates remaining battery power
• Flashlight can blink out voltage with 0.1V accuracy
• Intelligent memory function for brightness levels
• Direct access to ultralow and turbo outputs
• High transmittance glass
• Stainless steel bezel ring protects core components from damage
• Constructed from aerospace grade aluminum alloy
• HAIII military grade hard-anodized
• Waterproof in accordance with IPX-8
• Tail stand capability
Mode,Lumens and runtime:
| Mode Groups: | Runtime and Lumens (manufacturer tested,it will be a little bit different from the real data ) | |||||||
| Group1: | Moon 2LM/1500h | Turbo 5000LM/40min |
| Group2: | Moon 2LM/1500h | Low 160LM/33h | Turbo 5000LM/40min |
| Group3: | Moon 2LM/1500h | Low 70LM/66h | Mid 1250LM/8h | Turbo 5000LM/40min |
| Group4: | Moon 2LM/1500h | Ultralow 10LM/150h | Low 160LM/33h | Mid 1500LM/6h | Turbo 5000LM40min |
| Group5: | Moon 2LM/1500h | Ultralow 10LM/150h | Low1 70LM/66h | Low2 160LM/33h | Mid 1500LM/6h | Turbo 5000LM/40min |
| Group6: | Moon 2LM/1500h | Ultralow 5LM/150h | Low 70LM/33h | Mid1 240LM/17h | Mid2 1100LM/10h | High 2500LM/3h | Turbo 5000LM/40min |
| Group7: | Moon 2LM/1500h | Ultralow1 10LM/400h | Ultralow2 35LM/140h | Ultralow3 95LM/54h | Low1 160LM/33h | Mid 1350LM/8h | High 2500LM/3h | Turbo 5000LM40min |
| Group8: | Moon 2LM/1500h | Low 160LM/33h | Mid 750LM/17h | High 2100LM/5h |
| Group9: | Moon 2LM/1500h | Ultralow 10LM/150h | Mid 520LM/20h | Turbo 5000LM/40min |
| Group10: | Moon 2LM/1500h | Ultralow 10LM/150h | Mid 1500LM/6h | Turbo 5000LM/40min |
| Group11: | Moon 2LM/1500h | Low 160LM/33h | Mid 1350LM/8h | Turbo 5000LM/40min |
| Group12: | Moon 2LM/1500h | Ultralow 5LM/600h | Low 150LM/33h | Mid 1700LM/5.5h | Turbo 5000LM/40min |
Package included:
1 x BLF Q8 4X XP-L 5000LM Professional Super Bright LED Flashlight
2 x Flashlight Body Tube O-ring
1 x Flashlight Head Lens O-ring
1 x Switch cover
1 x English Manual
