BLF Q8 driver PCB parameter request
I am designing a driver board the same size and with the same mounting holes as the Q8 driver for the lantern project. I need some size dimensions for the PCB including
1. board diameter
2. center to center hole spacing for the two mounting holes
3. mounting hole diameter
4. dimension for for the shelf on which the PCB rests so as to keep parts out of this area with some margin.
5. centerline diameter of the positive battery ring trace.
I appreciate any help you can provide, thanks!!
Texas_Ace has already made drivers for the Q8 and will have all the relevant dimensions and specs for you. In fact, you can just download his PCB design and do what you want with it. For more details, contact him directly.
thanks for the feedback, I will ask him directly.
