I also have the same question that pilotdog had in post #79 above re. 105C. More exactly, can I pull the MCU from one of these and use it, as-is, on this BLF10DD:
Hmm, you’d think that someone (including me) might have answered that. The MCU is definitely no problem. You may use any standard Nanjg firmware w/out modification.
The other parts are all going to be tight but should fit AFAIK - I haven’t built any of these. AFAIK these are 0603 pads and of course the parts on the 105C are 0805 parts, so they sit right on top of the pads.
EDIT: I just checked your link. That’s not a Nanjg product, so who knows. EDIT2: the answer is no.
Looking at the board and also the parts list linked in the BLF15dd thread (BLF15.17DD Info Thread - Reference), the parts list has 3 resistors, a 19.1K, and 4.7K and a 130 ohm.
Just unsolder it w/ a solder rework station, plop on the BLF10DD/12DD and voila…you have the exact same modes as the 105C on the much smaller board, you don’t have to reflash.
Reverse voltage protection. Bypassing D1 is fine (you lose reverse voltage protection), but you must reflash your firmware with adjusted LVP values or LVP will be very wrong.
This is going to sound like a weird question, but would this driver even work if I used this FET temporarily:
I’ve been scrounging around my junk box all night, and that’s been the only thing close to a MOSFET that I was able to find thus far. It’s a SOT-23, but I guess it’s the “regular”/non-micro3 SOT-23, so is it too large?
Also, it’s Rds(on) is quite high, but I was just wondering if I could use this until the one I ordered from Digikey comes in, just to see if the driver works?
I don’t think it will survive long. VERY LOW Continuous Drain Current
You can solder a normal SOT-23 on micro3 SOT-23 pads, you just have to bend the legs in a little bit, I believe C_K found that out when he ordered a different MOSFET and it came in a little bit bigger size
