I've been looking at the Boruit Z001 for a while. Fat bodied lights with serial cells are harder to find than hens teeth. There's a ton of soupcans out there, but they're all parallel.
I really got focused when OldLumens started doing a mod on one, but then...arrrrrgggh...Justin!!! You're changing it to parallel!! He got it nice and bright, but I wanted series.
Lately I've started playing around with boost drivers after seeing what TomE was doing with the 7 and 9 emitter KD boost drivers. I knew the Z001 was underpowered and really wanted to see if it would thrive with a beast driver.
I didn't go into detailed breakdown photos because it's already been covered in other threads.
OldLumens:
DayLighter:
https://budgetlightforum.com/t/-/14661
First off, I replaced all the LEDs with XM-L2 U2 1A on Noctigons wired in series with 24AWG Teflon wire. I've been using Teflon a lot for wiring multi emitter lights because it is lower profile, and you can bend it to whatever contour you want. I also replaced the centering discs that stick up too high with the lower profile wing type. The Teflon wire made for a very neat and tidy job. Since the photo was taken, I've replaced the two driver leads with 20AWG Teflon also.
I removed the stock driver from its base so I could attach a 9 XML KD beast driveR, but first I had too fix some resistance problems with the Battery/Ground contacts.
The first photo I borrowed from OldLumen's thread. I basically added copper braid to both springs the same as Justin.
When checking with my ohm meter, I found I couldn't get any continuity tone from the chromed surface of the spring caps unless I scratched at them with the probes, so I filed the surface down to brass. I also drilled a hole through the middle of the Battery + spring cap and soldered a piece of 14AWG wire, and filed it flush.
Okay. Let's get that beastie mounted.
I copied TomE and filled the gap between the two boards with Fujik. You can see the little nuts and bolts that secure components from the battery side of the board.
I had attached long 20AWG leads from the emitters which I planned to run through the tube and solder to the driver, but when I looked, the negative wire on the driver isn't soldered on, but comes up through the the board from the center. The stock leads were to short to attach and still be able to screw in the reflector retaining screws. No option but to splice.
Battery end all tucked in.
I started taking tail readings by touching the leads to either side of the switch on the battery holder. Probably not the best way to get good readings, but it'll have to do.
While I was experimenting, the light started flickering and shutting off. I thought maybe the switch blew, but it tested OK. It seems the springs, which were not that snug with my unprotected cells had sagged from the current and the batteries were loose.
I replaced the springs with heavy IOS springs. "The big nasty ones" as Comfychair calls them. A bit of copper braid and my current readings improved. I'll probably jumper the traces when I have time.
Tail readings from leads pressed against the in/out tabs of the switch on the battery holder. 3 x INR18650-20R Samsung.
100% - 6.70A x 3 = 20.10A = 2.87A per XM-L2
75% - 4.87A x 3 = 14.61A = 2.08A
50% - 3.15A x 3 = 9.45A = 1.35A
30% - 1.67A x 3 = 5.01A = 0.71A
10% - 0.39A x 3 = 1.17A = 0.16A
All I can say is this torch is pumping out tons of light. A compact flashlight that acts like its a foot and a half long. I just knew this would be the one! Seven XM-L2 @ 2.87 per emitter is a lot of light in my pocket.
I know from my tests it will do 3.2A with regular XM-L on aluminum. I recorded a lot of readings using the 5,7 and 9 versions of this driver with 5,7 and 9 XM-L's. With 5 XM-L on aluminum and the 9 emitter driver I saw 4.7A. I'll post my results when I get a chance, so along with TomE's test results we can get a better understanding of these boost drivers.
I've been waiting for summer, but now I have to stay up later for it to get dark.
BORUIT Z001 beside COURUI Big Head
Thanks for listening.
. Also got a J18 with 6 LED's and the 7X driver, and that's still doin well. These beast drivers seem to come with high risk. My first J18 w/beast driver didn't last too long - Daylighter had it and died after bout 15 mins of use. With all the 7X and 9X drivers I've seen, same slow mode changing.
