Brand New RD6006-Max 60V 6A 360W Digital DC Power Supply is now available!
Hi everyone, our brand-new RD6006-Max power supply has officially launched!
Limited-time launch discount with limited stock — act fast!
Promotional Pricing (Limited Time Only)
• RD6006-Max: $46.99 USD | Regular price: $61.5 USD
• RD6006-Max-W / RD6006-Max-RS485: $50.99 USD | Regular price: $65.5 USD
Promotion Period: 10.22-10.28 (PT)
Stock note: Only 100 units available at this special price.
Once sold out, items will revert to regular price immediately!
RD6006-Max : [u]404 page
Key Upgrades vs the original RD6006
1. Larger display
3.2-inch screen vs original 2.4-inch screen
2. Updated communication port
Updated to USB-C connection to PC software control compared with RD6006 Micro-USB port
3. List Output
New List Output function, support 10 data groups for voltage/current/time/cycle times, you can program the output by yourself for different settings
4. Pointer Style
New Pointer Style display, Classic pointer dial UI. The red pointer swings in real time with the load, and digital readings are displayed simultaneously for more intuitive debugging and testing.
5. Output indicator LED
LED lights up when terminal outputs power, easy to check status even in dark environments
6. Extra protection functions:
New added Under-voltage protection, output short-circuit protection, timer shutdown function
Hello, in this video we show the list output page on RD6006-Max, 10 sets of voltage/current/time presets, Supports cycle count setting; auto-switch to next group when time is up, Status bar displays WAIT/RUN/END in real time
Still no new models with remote sensing?
For the remote sampling, we only have RD6006P which has this function, We used to add in hardware to achieve this function, but when it is assembled, it is not convenient, We haven’t made it on the software now
Hello, in this video we show the Output LED indicator of RD6006-Max, It will light in different color to tell you the output status
Hello, in this video we show what is changed on RD6006-Max based on RD6006, including hardware, new features, and new functions
Hello, in this video we show the special functions which are added to the RD6006-Max: Timed off, input under voltage protection, output short circuit protection
Hello, in this video we show voltage and current accuracy of RD6006-Max
Hello, in this video we show the input voltage protection of RD6006-Max, It can use 6-70V DC input, when input is over 72V, it will show over high input voltage warning and turn off the output, if you use over 75V, it will shut down, it can withstand up to 100V DC max in short time.
If you reverse the input positive and negative, the device will not be power on, but it will not be damaged too. If you are charging a battery with red + terminal. the inpu power is cut off, The battery power will go back to the input, the screen will light but no damage.
Hello, in this video we show the Source effect of RD6006-Max, When you turn on the output and your input voltage is changing, the output is still stable
Hello, in this video we show the battery charging of RD6006-Max, there is a battery charging terminal, with all kind of protections, now terminal LED also shows the battery status
Hello, in this video we show the System setting of RD6006-Max and what each setting option means
RD6006-Max 60V 6A 360W Digital DC Power Supply is now available!–Quick memory recall operation
