In an earlier thread where I was looking at potential 2xAA hosts, Anyone have this 2xAA light ("N4"), I had mentioned that I had found the Ansmann Futura on Ebay:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=271614964745
Since I got a couple of these, I spent some time disassembling (read: “destructive de-construction”) one of them.
Here’s a pic of the battery end of the head:
There’re some holes in the black plastic ring, and I figured that if I could use those to turn the ring and remove the pill, if there was one. However, I found that the ring wouldn’t come out, even if I kept turning it, so I finally ended up using my Dremel to cut the ring to pieces, and finally got things apart. I also found that the light does have a “traditional” pill, at least partially, and that the head was actually 2-part, and had a “bezel ring”!!!:
So here’s everything taken apart:
From the pics, you can see that this light does have a driver, but the diameter of the driver is way smaller than the diameter of the head and the pill, so for whatever reason, rather than making a driver board that had the “right” diameter, the mfr used that black plastic disk to compensate for the difference in the diameter of the pill vs. the driver.
Before doing all of this disassembly, I was kind of disappointed in this light as a potential 2xAA or 2x14500 host, but now I think that it has good possibilities!!
