Brightest bulb for 2D MAG-Lite
I’ve got a 2D Mag-Lite that I’ve had for about 6 years now. It really isn’t very bright anymore. I want to replace the bulb with the brightest one I can get that will fit in this flashlight. I’m a bit of a battery guru, so don’t worry about how much power the bulb needs. I can retrofit some 18650 cells or any number of AAA NiMH cells to give it the power it needs. I’m not so much concerned about how long the batteries last as I am how bright the light is. I want something with over 1000 lumens.
Thanks!
Member here Vestureofblood makes some really nice stuff available on his website www.asflashlights.com
I should add that I’m only looking to spend about $15 bucks here. Maybe that limits how bright of a bulb I can get.
I’d slide the mag into a drawer, where it belongs and get a Convoy S2 with 8*7135 driver. Gives you the output you’re looking for, multiple modes and will almost fit behind your ear. If you want more throw, Thorfire C8 is in your budget and still very pocketable.
I always wanted to do a ROP Maglight.
It looks expensive to do it right but maybe a glass lens and a bulb would be OK for limited use.
ROP
:smiling_imp:
Mags can be modded if you are able to make your own heat sink or source it cheaply to stay within the budget. emitter and driver can be had for a few bucks.
The overall build quality and form factor/design of the light is good, mine are 10+ years old and look like they are new.
Perhaps next time you should specify your budget first before I suggest expensive things… lol j/k.
Whats the difference between the 8*7135 and this one? Amazon.com
I don’t see how many Lumens it puts out.
I’d recommend you just get a Thorfire C8s. It’ll throw more like a maglite. You’ll be more than satisfied and it’s a good platform to start if you get into modding.
If you want to stay incan, maybe this would do the trick:
It is a Osram 50W IRC halogen spot driven by 12 AA-Eneloops. I wanted to share the details with you anyway soon. What I can say for now is that with minimum budget it is pretty bright!
Till
It’s not as bright as it only has half as many chips 4*7135 as opposed to 8*7135
Good call. That thing looks badass. Thanks.
Just use one of these 1000 lumen drop in’s.
http://m.ebay.co.uk/itm/MAGLITE-LED-UPGRADE-Conversion-Bulb-3-4-6-D-C-Cell-CREE-XP-G2-Torch-3D-4D-6D-/221769965649?nav=SEARCH
Or one of these if your budgets that tight,
