Brinte PT16 Tactical Flashlight With TaIl Dual Switches~
Brinyte PT16 2000 Lumens Rechargeable Tactical Flashlight, USB-C Compact Dual-Switches LED Bright Light with Memory Function, IP68 Waterproof for Searching Emergency Camping
  • :white_check_mark: Super Bright: The PT16 flashlight is equipped with a SFT40 High-Intensity LED, the maximum brightness can reach over 2000 lumen, with a beam distance of up to 556 yards, easily light up corridor and road. It is the perfect choice for outdoor activities like searching, emergency, camping, hiking and repairs inspections.
  • :white_check_mark:Multiple Lighting Modes: The PT16 tactical flashlight provides 4 brightness levels (low, medium, high, turbo), as well as 2 special modes (strobe, SOS) for any situation. You can easily switch the illumination modes you need using the dual tail switch(Tail main switch for turbo; tail side switch for adjusting modes).
  • :white_check_mark: Smart Switch Design: This torch has a lockout switch design to prevent accidental activation. In off state, the front side switch will be automatically locked after 1 min. Press the front switch 3 times quickly to unlock/lock it. After manually locking the front switch, the indicator will remain dimly lit for 1 min to help locate the light in the dark.
  • :white_check_mark: Convenient Memory Funtion: Long-press the front switch to turn it off; One-press the front switch again to turn it on. The PT16 will memorize the mode you used last time when you turn the light back on, making your daily life easier and more convenient.(Only the front switch has memory function. If using the tail switch to turn on the light, it is not applicable.)
  • :white_check_mark:Easy USB-C Charging and battery indicator: The PT16 flashlight comes with a USB-C charging cable, reducing the burden of electricity charged outdoors.The built-in power indicator of the side switch clearly displays the remaining battery level in real times and friendly reminds you to charge the flashlight in time. It lasts up to 280 hours on low mode after a full charge.
  • :white_check_mark:Waterproof and Shockproof: This light has an IP68 waterproof rating and is capable of withstanding drops from up to 1 meter, with a quality casing that is sealed to prevent leakage. You can confidently use this torch for outdoor adventures, as it can withstand rain, splashes, and accidental drops.
See more details: BRINYTE PT16 Tactical Flashlight
