【Brinyte New Release On Amazon & Looking for reviewers】
Brinyte XP22 Scorpion Dual head gun light
Like the smooth shape of a scorpion, accompany you to explore the mysteries of the night
BRINYTE XP22 Scorpion ——Dual head gun Light
- Electronic lock key design
- Special magnetic charging design, charging faster
- Tempered glass lens, anti-abrasion,anti-scratch, and drop-resistant
- With overcharge, over-discharge and overheat protection functions Vertical switch design, holding the gun more convenient and stable
- Charging intelligent power indication design, with flashing, instant lighting, and other functions Equipped with 900mAh integrated li-polymer battery, more durable and long-lasting
- The screw rod is fastened and assembled on the gun body to easily resolve the impact of the gun’s recoil
- Using aviation-grade aluminum AL-6061-T6, and military-grade 3 hard anodized on surface
Enter promo code【K7NVBFRE】at checkout to redeem 15%
Shop now https://www.amazon.com/dp/B0BHX5G2R3
Take your XP22 Scorpion and show off your cool charm!!
See more details: Brinyte XP22
Brinyte HL28 Artemis Tri-color Hunting Headlamp
Hounds accompany you on your hunting trips, as does the Brinyte HL28
BRINYTE HL28 Artemis ——Zoomable Tri-color Hunting Headlamp
- Patented tri-color lighting sources switch design, easy to switch between different colors
- Stepless dimming knob switch design, you can choose 3~100% of the illumination brightness
- Rotating head to a beam zoom in and out
- 0~90 degrees adjustable head
- Powered by two 21700 rechargeable Li-ion batteries with a battery pack
- Intelligent battery indicator for charging and checking
- Magnetic charging port designed to charge conveniently and faster
- The headlamp bracket, soft silicone pad, adjustable strap makes it more comfortable to wear
- Enter promo code【GRSGBXRT】at checkout to redeem 15%
Harvest the last of your prey with Brinyte HL28!!
See more details: Brinyte HL28
Brinyte E18 Pheme EDC Light
I do like the tube design and switch
BRINYTE E18 Pheme ——Multi-functional EDC flashlight
- A variety of lighting functions: Memory function,Instant lighting, double-click highlight, strobe, SOS Intelligent power indication
- USB Type-C charging port provided for convenient charging
Powered by one 18650 rechargeable lithium battery
- The magnetic tail cap can be attached to iron products
- The round hole of the tail cap can be used with a lanyard/keychain, with two-way clips easy to hang lighting and carry
- The barrel and tail cap have a special polygonal knurling design, making it more comfortable to grip with a better anti-slip performance
- Enter promo code 8XWCXSB8 at checkout to redeem 15%
Who doesn’t want a small, sturdy and useful lamp !
See more details: Brinyte E18
Brinyte A02 Apollo Keychain Light
A small key light, but it gives you great power in the dark
Brinyte A02 Apollo —— Portable keychain light
- A variety of lighting functions: LOW-MID-HIGH,STROBE
- Built-in one 150mAh Li-Polymer
- Over-heat protection function
- Made of durable A6061-T6 aluminum
- Premium type HAIII hard-anodized anti-abrasive finish
Come and take your key light!
See more details: Brinyte A02
Brinyte HL18 Noctua Adujustable Headlamp
- Max 1600 lumens and beam distance 308m
- Powered by one 18650 battery
- 0~90 degrees rotating head
- 0-120 degree adjustable bracket constructed of durable plastic
- A mesh style headband makes it a lot cooler and for hand-free use
- Easy Magnetic Charging, smart battery indicator
- Tested with IP66 waterproof and 1.5 meters impact resistance
See more details:Brinyte HL18
Brinyte A01 Apollo Four color EDC Light
- 4 single colours and 8 modes integrated in one light
- Constant white, red, blue and green and flashing white, red, blue and green
- Compatible with 1*AA battery or 1*14500 battery
- Non-slip and comfortable silicone ring Can be used more easily with lanyard
- Practical and convenient mode memory function
- Toner in the shell optimizes lighting effect
- Plastic transparent shell transmits light to all angles
- Professional waterproof design, depth rated to 150 meters underwater
- Reverse polarity protection, to protect the light from improper battery installation
- Aircraft-grade high-strength aluminum AL-6061-T6 used with type III military grade hard anodization technology
See more details:Brinyte A01
