Brinyte HL28 Hunting Red Green White Headlamp
Brinyte HL28 Artemis LED Rechargeable Headlamp,90°Tilt Comfortable Flashlights with Zoomable Red Green Hunting Light,IPX6 Waterproof Head Light for hogs Coyote Fox Bobcats Pig Hunting
Emitter:CREE XPE2 R5 RED*1 & CREE XPE2 R5 Green*1 & CREE KWCSLPM1-TG-8N7P*1
Battery:21700(4800mAh)*2
Working Current:3.0-4.2V
Maximum surface temperature (℃):60
Inside the box:
See more details: https://www.amazon.com/dp/B0BHX7R12S
15% OFF Promo Code For My Friends : GRSGBXRT
Feature: :) :) :slight_smile:
  • Patented tri-color lighting sources switch design, easy to switch between different colors
  • Stepless dimming knob switch design, you can choose 3~100% of the illumination brightness
  • Rotating head to a beam zoom in and out
  • 0~90 degrees adjustable head
  • Powered by two 21700 rechargeable Li-ion batteries with a battery pack
  • Intelligent battery indicator for charging and checking
  • Magnetic charging port designed to charge conveniently and faster
  • The headlamp bracket, soft silicone pad, adjustable strap makes it more comfortable to wear
  • Overcharge, over-discharge, and overheat circuit protection functions
  • Reverse polarity protection prevents damage from improper battery
  • Aircraft-grade high strength aluminum AL-6061-T6 with premium Type III military hard-anodized anti-abrasive finish
It’s not CREE, it’s Osram.
Sorry, we accidentally typed them into cree when we uploaded the text, we will correct it later, thank you for your reminding.
Sorry everyone,Although I wanted to modify the original post, I couldn’t find the edit button after the page changed. Just a little warning here. Actually this is Osram KWCSLPM1-TG-8N7P*1. Thanks Funtastic for the reminder.
Brinyte HL28 Artemis 3-Color-In-1 (Red,White,Green) Switch Hands Free zoomable Hunting Headlamp :red_circle: :green_heart:
90°tilt Headlamp with red green light,comfortable to wear, easy to change led color in one led switch,is ideal for hunting and outdoor activities that require two hands at night :kissing_heart:
I was sent this for review in 2022 and the top strap mounting point at the back broke, never heard back from support about getting it replaced so I could review it. I was told in Dec 2022 that the rear bracket was being redesigned, did this ever happen?
Hi Funtastic,sorry for the late repky.
I missed the message.
Can you please contact me in private about the details?
Which lamp were you sent for review? We did upgrade the bracket. But I’m not sure which one you mean.
Thanks a lot!
