Brinyte new products
Thank Tai for sharing~ 😊💯
Brinyte XP22 LED Flashlight 1300-Lumen Low-Profile Compact Rail-Mounted Weaponlight with Built-in Pressure Switch Picatinny Rail Locating Keys,Magnetic USB Rechargeable Tactical Light,Black❤️👍
A great and powerful two into one light that is perfect for so many things including rifles, bow and arrows, military helmets and more. 🍻🔥
Learn More👉👉: https://www.amazon.com/dp/B0BHX5G2R3
Check the video by Robert!
In less than 2 months you have created eight separate posts about this same flashlight.
I’ll give them some credit. It’s no longer listed as running on a AA battery. But eight post must be a record. Also the Brinyte XP22 Rifle light is climbing the selfie list
Oh sorry, can’t I create a new post? I thought it was similar to FB posting. Or do I need to post a new post under the previous one? If there are friends who are familiar with the post rules, please let us know how to correct this. Thank you!
The video quality is terrible, but at least I can hear (and understand) the audio:
https://youtu.be/anwy2MPT5RE
Yes, we have corrected the information issue regarding the battery mentioned earlier to avoid any misunderstandings. Also, I apologize for the negative impression caused. We will study the relevant rules of the forum again and standardize the measures for posting in the future. Thank you for your reminder!
No clue how the facebooker works. Not relevant.
I’m not the police. I’m just trying to help.
Okay, thank you for your help. I just contacted the moderator for help and understanding the relevant rules and content. Thank you.
Thanks David for sharing~❤️
👍Maximum output of 1,300 lumens & 260 meters thorw
👍Built-in vertical pressure switch design
👍Magnetic Charging system
👍Lockout & Steady & Strobe Mode
👍Low profile & Shockproof
👍Quick install and removal ; Ultra-compact and lightweight
👍Also can be a tool light
Learn more🔥🔥: https://www.amazon.com/dp/B0BHX5G2R3
Thanks Dreko for sharing~
Brinyte XP22 1300 Lumens Rail-Mounted Picatinny Rifle Light💥
Check out this light​:sunglasses::+1:: Amazon.com
Brinyte XP22 1300 Lumens LED Tactical Flashlight with Strobe, Low-Profile Rail-Mounted Compact Weaponlight with Built-in Pressure Switch Picatinny Rail Locating Keys, Magnetic USB Rechargeable
Learn more: Brinyte XP22 1300 Lumens
:collision:16%Promo Code-:collision: UQ3LYQHY
BRINYTE XP22-Good build quality out of the box design!🔥🔥
Thanks David for offering his professional use experience and improved suggestion~❤️👍
“I purchased the XP22 because it had an interesting design and I wanted to see how durable and compareable it was to other lights at the same price point. For example the Odin Mini or the Streamlight protac as they also have rechargeable options. As mentioned this has an outside the box design with two lamps. I happen to have a A2 fixed front on my upper and thought it might be a good fit for a top rail mount solution. 😎😎😎
It was very slim and fit just fine. The sight did not interfeir with the throw of the lamps. With the switch placement it wasnt uncomfortable either to accuate with my thumb but didnt feel completly natural with the placement of the switch at the tail. I also mounted it on the side. Even though it seemed to be better mounted on top with the dual head, it was actually more comfotable to accuate from the left side rail since I run a full quad rail gaurd. I acuate the light with my thumb. The throw on this lamp seems very nice as well. I have attached photos for reverence. im not sure if the dual head helps with that or if that is because of the focus of the beam and the way it was designed. Either way, good throw! 💪😎
I removed the lense cap as I wanted to see if this could also be “serviced” by swapping lenses and or LED lamps. I found there is a seal on the lense to prevent moisture which was good. I did notice that at the bottom of the cap there was no o ring to prevent moisture coming in the other end. In most situations, rain, snow etc it would probably be fine and not damage the internals. Id obv advise against submersing it in water. Maybe in future revisions this o-ring can be added, I dont believe it will be an issue for most though. 👌✌️
The charging placement is in the front which is nice as you wont have to remove the light from the rail to charge it. It is however a smaller magnetic contact pad. Something I would like to see is maybe the pad can be a little bigger for a stronger magnetic connection on the bottom of the light. The light could then maybe be removed via a locking lever for ease of use and charging. 🧐🎈
This would look similar in fasion to a HOLOSUN 510 or 515 locking lever. Slim, to keep the lights footprint small and non intrusive to any grip or switch accuation. This would make for quick removal and installation, and retain ease of charging.
Over all, I think this is a high value light and it seems to be built pretty sturdy. I did drop it upon opening and while it wasnt from a high location, it did not mar easily nor did the coating take any damage. I think this could be used out in the woods efficiently as well as Airsoft events. The strobe works very well too which is a big plus! Over all for the price this seems to Make it a good competitor. My cretiques are not negatives or reasons not to purchase, but rather enhancment suggestions I would like to see on future revisions or different models BRINYTE might come up with in the future."😆💯
Don’t hesitate to take one👉👉: https://www.amazon.com/dp/B0BHX5G2R3
Shoot with your XP22 Weapon Light!💪💙
Thanks Brian Edmondson for sharing~❤️
Brinyte PT16A Tactical Flashlight, 3000 Lumen USB-C Rechargeable High Lumen with Strobe Memory Function, Dual Rear Switches with Holster Clip for Home Camping Emergencies Hunting Outdoor :+1:
:point_right::boom:17% Promo Code CGC4UHLF
Learn more🎁: Brinyte PT16A
Brinyte XP22 Scorpion Weapon light first impression🔥
“Out of all the brinyte lights I have tested recently this one is pretty sweet. I prefer neutral white in my flashlights to show true colors but first impressions I like it”
:camera:Matthew Reinhardt
Learn more❤️: Amazon.com
When you look through your telescopic sight ( which you have not shown mounted ), don’t you get reflective glare off the suppressor from the light?
We have asked some reviewers. Their feedback is that the impact is not significant. Previously, someone took XP22 to participate in night shooting competitions, and their feedback was that the performance was very good. Many contestants and referees have asked about this lamp.
Perhaps due to the lower thickness of the XP22, there won’t be too much obstruction when viewed from the sight after installation.
Thanks Justin for sharing~:👍💯
Discount included🔥🔥
13% off discount code: SFR3976E
Learn more: https://www.amazon.com/dp/B0BHX5G2R3
Adventuring with the PT16A High Lumens Tactical Flashlight. This is very handy for keeping your hands free underwater, lighting with the red light you can create very nice effects. ❤️🔦
✍ Max 3000 Lumens & Max 458 Meters Beam Distance
✍ Multiple Modes (low,mid,high,turbo,lockout,memory,strobe,soso)
✍ Handy Accessories (Finger ring, 360 Degree rotable holster,pocket clip,tactical ring,lanyard)
Video by EKE ACRES 👍
👇If you are interested in it, check the link to get it! 🔦
Product link: Brinyte PT16A
