We will consider your suggestion and thank you very much for your sincere reply and suggestions!
Thanks Kyle for sharing!
Brinyte PT16A 3000 Lumens Rechargeable tactical flashlight- designed specifically for law enforcement, military, security, and all first responders.![]()
16% Off discount Code on amazon: YPDTL7KT
Looks like some nice improvements. If that charging port is waterproof when open even better. I’d rather have move lumens and less throw. So nice change on the LED. My duty light needs to light up a wide view so I don’t miss anything. 450 meter throw sounds good but what can you really see at that distance. Kept the head small so it can still be worn on a duty belt comfortably without eating holes in your shirt.
-Brinyte XP22 Great Weapon Light![]()
"Great light, this wml has the perfect amount of brightness. The magnetic charging is very convenient, I have another pistol light and I have to take the batteries out to charge it so that’s a very big plus for me. The switch is very firm and durable with really nice spring tension so the likely hood of an accidental discharge is unlikely. I was thinking there was going to be 2 beam patterns but they are aligned so well that it appears as one beam. The spring loaded mounting system makes it a breeze to install and remove the light. It’s defiantly very durable and going to hold up to some abuse because the whole light is made of aluminum. So far it has been great and holding up just fine. "
Rapid blue 6.2
Thanks Jasper for sharing!![]()
Super bright and pretty cool! Compact and durable…
This light is just what you need for self defence or emergency night searches. ![]()
Learn more👉: PT16A
16%OFF discount Code: JSPREDC1
Unboxing Brinyte XP22 - Dual Lens Rail-Mounted Picatinny Weapon Light:flashlight:![]()
With the compact and low profilied body,can remove the shadow ahead. Dual lights design help to eliminate barrel shadows compared to single source rail lights, and the dual light system focus into one hotspot allowing for a brighter light which can reach 260m at maximum. ![]()
Shaun
See More Details of Brinyte XP22 on Amazon:
Brinyte XP22 Weapon Light
#brinyte #xp22 #weaponlight #riflelight #picatinny #airsoft #gun
The Brinyte XP22 gun light is a powerful and durable tactical flashlight designed for use with firearms. It features high-quality materials, multiple modes, and a rechargeable built-in battery, making it a popular choice for law enforcement, military, and civilian gun owners.![]()
Thanks Brent for sharing~![]()
The XP22 can be used not only as a weapon light, but also as a headlamp, bow light, camera light, Scooter light in many unexpected combinations!
Come and explore the new ways to play!![]()
Use Discount code LFATO110 to save money!![]()
Pick yours
: https://www.amazon.com/dp/B0BHX5G2R3
Thanks Gene for sharing~👍
1300 Lumens Super Bright Weapon Light ![]()
-With 1 steady mode(high) & strobe
-low profile,will not block your eyes
-Dual lens to concentrate the light beam
-Magnetic charing system
Learn more👉:Brinyte XP22
Thanks Yushiyya for sharing!![]()
The video features a brief unboxing of the XP22, showing us what it looks like mounted on a gun in the sunlight, Yushiyya’s videos usually focus more on product and game storytelling, and he’s going to be showing us more creative ways to play with the XP22, combining outdoor nature and game storytelling! Let’s look forward to it!![]()
If you’re interested in the XP22, my friend has a 16%off discount code “2Crakd11”, so don’t hesitate to click on the link below to explore more ways to play with the XP22 with Yushiyya!
#riflelight #weaponlight #picatinny #railmount #arlight #ar15
Brinyte XP22 Dual Lens Rifle Light
GOOD FOR USE WITH DIFFERENT OPTICS
The light doesn’t effect your sight or the image you see through the optic and doesn’t burn your eyes at all. Dual Lens deliver brighter light and avoid shadowing from the rifle, barrel, or a suppressor.![]()
Learn More: Amazon.com
#weaponlight #rifle #ar15 #ar #picatinny
Brinyte PT28 Palm-sized Tactical Flashlight For Police Lawenforcement Self defense Camping Hiking Cycling Searching Home Car Repairing Dog Walking:love_you_gesture:![]()
Max 1600 Lumens 245 Meters
Easy to control with tail/side switch
Memory Function
use 18650 rechargeable battery
*Magnetic charging system and smart power indicator
Anodized surface treatment, aluminum body and IP68 waterproof
with tactical finger ring /holster/lanyard
Learn more: https://www.amazon.com/dp/B09156849G
【Brinyte PT16A 3000 Lumens Tactical Flashlight】—Well made and solid flashlight.On “turbo” mode, It can light up most of your whole backyard, and also something well over 100 meters away. You can see in the photos that it can easily light up most of a soccer field all at once, and the length of that field is no problem at all. The beam is a fixed focus - it is not zoomable. It is a nice, versatile light. ![]()
Jon
Learn more:point_right:
: Amazon.com
Climbing at night requires a reliable partner! ![]()
The Brinyte PT16A 3000Lumens Tactical Flashlight is definitely the right choice for your lighting!![]()
Learn more![]()
:https://www.amazon.com/dp/B0CQT3ZX8K
BRINYTE XP22 Picatinny Rail Mounted Rifle Light:heart:
The XP22 is a brand-hot compact offering in our tactical series.
Low profile, magnetic charging, aluminum body and IPX6 Waterproof with High/Strobe/Lockout mode.
Dual lens design removes the shadow and delivers brighter light, reaching up to Max 1,300 lumens and 260 meters.
Multiple application scenarios, can be used as weaponlight, helmet light, crossbow light, etc.
With its compact size, high performance, and ultra-solid build, the XP22 is 0ne of the most feature-packed WML options on the market.
#picatinny #weapon #rifle #ar #ar15
Learn More:point_right:
: Brinyte XP22 Picatinny Flashlight
Take your PT16A for an outdoor adventure~:green_heart:![]()
#brinyte #tactical #police #lawenforcament #camping #hiking
Learn more: Brinyte PT16A
Thanks James sharing video for PT16A Tactical Flashlight ~❤️
-Max 3000 Lumens Output/300 hours run time
-Easy to use with dual tail switch
-USB-C Rechargeable Charing
-Tactical Use & Daily Use
-Memory & Lockout Function
-Useful Accessories
PT16A 3000 Lumens: Amazon.com
PT16 2000 Lumens: Amazon.com
