Brinyte new products
Hi, are you guys talking about corona? Or something specific? It could be that because the shooter was shaking and didn’t focus while taking the picture, the picture was taken with blurry dynamics, and it would look dizzying.
The shape that will appear on the wall is mainly the shape of the flashlight head, the light itself is not shaped like that.
I’ve attached a few pictures of the light shining from the flashlight taken by other reviewers below. Or if you guys have any suggestions about the flashlight after using this flashlight, feel free to leave a comment. We will collect feedback when we see it, and will rectify it in the upgrade based on your comments, thanks~!
Brinyte HL28 Red Green White 3 Colors In 1 Switch Hunting Headlamp. No need to replace the led when you are hunting at night.❤️💚🙌
Learn more: https://www.amazon.com/dp/B0BHX7R12S
#hunting #headlamp #headlight #coyotehunting #foxhunting #hog #hoghunting #rabbithunting #greenlight #redlight #huntinglight #huntingflashlight
Thanks Jon sharing his using experience for Brinyte XP22 Weapon Light~❤️❤️
"🏔️1. Lightest light that I have, with “daytime bright” light that can add light to a sun filled room, and be seen while shining on lit surfaces.💯🔦🔦
🏔️2. Extremely light in weight (especially for this kind of power and runtime of 1300 lumens for 70 mins). But it WILL NOT make the barrel “forward heavy” when wanting to add a reliable, but minimal footprint/weight for a light. I’m a smaller framed guy and less weight on a rifle helps me greatly and I’m always trying to slim down the weight of any rifle, when possible.🤟🔥
🏔️3. The entire mount, and system is smaller than most lights are, and it’s not bulky, so it is slim and trimmed to the lines of the pic rail — the body is the height of 1/2 inch, adding almost no bulk to a thinner m-lok attached pic mount, or by simply adding to any already current pic rail (upper rail for most rifles).🙌👍
🏔️4. Engagement of the button is very intuitive and has a good amount of pressure. It can be easily activated when needed, but won’t go off easily when brushed up against — sits flush and can take a little bumping around, without being activated negligently. It has to be depressed within the u-shaped guard, to be activated — I love that. I also really appreciate the lockout mode where I have the ability to lock the light off, to negate any chance of a negligent activation.😎😄
🏔️5. Still able to run an offset 1x red dot at 3 o’ clock position, without obstructing the view of the optic, in any way, when optic is placed on top of an lpvo (vortex strike eagle 1-8x) or when positioned underneath, and/or to the side.🔦💪
🏔️6. Can be run underneath of the rail, or on the side, as well
🏔️7. Has the ability to have light coming from more than one place, so if anything covers one light while barricading, it might still be able to give you light from the other diode. (More space to create the light— with minimal footprint, weight, and tail space).
🏔️8. Quick detach mount that’s tiny and very easy to use by hand.
🏔️9. So small, this can be run as a handheld, and added to, or used to replace another light that runs out of power. It’s a perfect light for a lineup of lights and batteries that will be used over the course of a night, rather than charging, and waiting to shoot between charges. I will typically charge up fully, and run replacement batteries, and even re-attach lights with the QD mounts, and can get a lot of shooting in while I charge 18650’s and the like in the car.
🏔️10. Slimmest light I have for a rifle, while still not being the lowest in output. It’s very bright for how small this is and does a great job of having a nicely controlled spill : center focus ratio. The center dot is the outline of two merged dots, and the spill is exactly what anyone would use for CQB, or anything within 25-50 yards.
🏔️11. Feels like nothing is on the rifle. I can’t feel the weight when I add it to a rail, and the slimline body style makes me forget that it’s there unless I want a light. (When added to an FN-15 DMR 2).
These are notes I took, while out shooting, with the light. I will edit or update, if anything changes, or if I find anything else that I’d like to add! Love how much power I can get with such a small amount of space and weight. Really liking this light."
Learn more💥💥: https://www.amazon.com/dp/B0BHX5G2R3
#flashlight #torch #brinyte #brinytexp22 #weapon #rifle #picatinny #ar15 #ar9 #mlok #tacticalflashlight #selfdefense #military
I would like to see an AA battery version of the E18. With a Nichia neutral white emitter.
Brinyte XP22 1300 Lumens Picatinny Rail Mounted Weapon Light
Learn more: https://www.amazon.com/dp/B0BHX5G2R3
#weapon #picatinny #mlok #rifle #homedefense #ar #ar15 #ar9
Brinyte HL28 Red Green White 90 degree tilt Zoomable predator Hunting Headlamp🔥🔥🔥
  • tri-color lighting sources switch design, easy to switch red/green/white color
  • can use stepless dimming knob switch to choose 3-100% brightness
  • 0-90 degree adjustable haed
  • magnetic charging design
Learn more👉👉: https://www.amazon.com/dp/B0BHX7R12S
#brinyte #headlamp #headlight #redlight #greenlight #huntinglight #huntingflashlight #flashlight #coyotehunting #foxhunting #hoghunting #predator
Brinyte T28 Red Green White Zoomable Predator Hunting Light
  • Adjustable Focus Beam
  • 3 colors can be switched within 1 second
  • Stepless Dimming switch to adjust the brightness from 2%-100%
  • IPX6 waterproof
Learn more👉👉: https://www.amazon.com/dp/B0915B2FSR
Thanks Alan for sharing!
In this episode, 2A-N-LA discusses the Brinyte XP22 Scorpion! If you are considering a budget friendly weapon light for your sub-gun the XP22 Scorpion could be an excellent choice!
Learn more:
Brinyte XP22 Link: https://www.amazon.com/dp/B0BHX5G2R3
20% OFF Promotion Code: XP22ANLA
#picatinny #weapon #rifle #ar #ar15 #homedefense #brinyte #tactical #flashlight #torch
Thanks Adam for sharing~
I love the way he introduces the lights like this, it’s like sharing with friends in an intimate way!❤️❤️
Brinyte T28 Artemis Red White Green Zoomable Predator Coyote Hunting Light🎁🔦🔦🔦
*3 colors in 1 switch,no need to replace the leds when hunting
*Stepless Dimming Switch, can adjust the brightness level flexibly
*Adjustable Beam-Zoom in/out
*with pressure switch and lanyard
*IPX6 Water Resistant
Learn more👉👉: https://www.amazon.com/dp/B08R77WRZS
Use our Promo Code: 💥FREEBO28💥
#coyotehunting #nighthunting #foxhunting #hoghunting #hunting #flashlight #torch #huntinglight #zoomablelight #redlight #greenlight #foxhunting
Thanks Eric for sharing!
Compact shape, metallic shine, impressive brightness! Worth a try!
🔥Use code LOAD2202 for 30% off!🔥
See more detail👍: https://www.amazon.com/dp/B0DHL2XHNJ
#picatinny #rifle #tactical #weapon #shoot #gun #ar #homedefense #ar15 #ar9
Thanks Felix for sharing!❤️👍
The Brinyte PT16A offers several operational modes, including a strobe and fade effect. The flashlight can be used directly from the holster even with the tactical finger ring in place. It has a solid head with three steel balls for added protection during outdoor activities. The flashlight also has a memory function to recall the last used mode, a lockout function to prevent accidental activation, and a battery level indication with a low voltage warning.🔦🔦
With a maximum output of 3,000 lumens and a 458-meter beam distance, this T6 aluminum hard anodized finished flashlight is suitable for various outdoor activities such as hiking, deer hunting, and camping. If you’re looking for a good tactical flashlight, check the link below for more information.🔥💯
Learn more:👍👉 https://www.amazon.com/dp/B0CQT3ZX8K
#tacticalflashlight #flashlight #torch #edc #police #lawenforcement #camping #hiking #climbing
【🏜️Brinyte XP22 Desert Tan/Sand Color🏜️】
Many of my friends have asked me “When will XP22 come in sand color?” “It would be great if XP22 had a sand color”.Today, the sand color you’ve been waiting for is finally here! 💯🔥
Different visual experience, low profile feature, smooth shape, excellent performance andpremium texture, install XP22 Sand Color on your rifle, helmet and other equipment, both high quality, practicality and good-looking, come and take away your XP22 Sand Color rifle light, explore more unique outdoor experience!😎❤️
Learn More👉👉: https://www.amazon.com/dp/B0DHL2XHNJ
Super big discount during Black Friday!Click the link to see more details!
【Promotional Product Summary - Hunting & Tactics Series】
🔦Brinyte Amazon Black Friday !:backhand_index_pointing_right:|16x16👉: https://www.amazon.com/…/8FA88663-6766-4486-8001…
🔦Brinyte XP22 weapon light!:backhand_index_pointing_right:|16x16👉:
Black - https://www.amazon.com/dp/B0BHX5G2R3
Desert- https://www.amazon.com/dp/B0DHL2XHNJ
🔦 Brinyte PT16A 3000 Lumens tactcal flashlight!:backhand_index_pointing_right:|16x16👉:
🔦 Brinyte PT16 2000 Lumens tactcal flashlight👉👉: https://www.amazon.com/dp/B0C8HCRFDR
🔦Brinyte PT28 tactcal flashlight👉👉: https://www.amazon.com/dp/B0915YBD3Z
🔦Brinyte T28/T28IR hunting light👉👉: https://www.amazon.com/dp/B08R77WRZS
https://www.amazon.com/dp/B0915KGW2M
🔦Brinyte HL28 hunting light👉👉: https://www.amazon.com/dp/B0BHX7R12S
🔦Brinyte T18 hunting light👉👉:
https://www.amazon.com/dp/B0B6W5ZVB1
Come to the Amazon store “Brinyte Flashlight” to choose your flashlight partner during the event!💕💕
#deals #blackfriday #discount #coupon #brinyte #flashlight #torch #camping #hiking #climbing #homedefense #hunting #military #police #headlamp #headlight #rifle #weapon #picatinny #ar #ar15 #ar9 #shotgun #gun #lawenforcement #shotshow #cybermonday #gift #christmas
https://imgur.com/a/kV5kskt
【Brinyte T28 Hunting Light- Perfect for it’s design and quality】
Thanks Brandon Stublaski for sharing~❤️
"I have several Brynite flashlights because I am so impressed by the quality designs and build quality. The T28 does not disappoint. Everything is so smooth to operate with an incredible fit and finish. The convenience of the built in instead of the changeable heads on the T18 is great! The range of light intensity fits it to any situation. Works flawlessly mounted with the pressure switch, or in the hand with the tail switch. The one thing I found is that I don’t like the on delay for the tail switch but I understand it. Without a recessed button like a pocket light, the delay keeps it from being turned on with a touch. I mainly use it in hand and see so many creatures of the night using it. I’ll show some pictures! This simple interface, and high-quality design make this a great light for many situations and I highly recommend it!":+1::100::sunglasses:
See more details​:point_right::point_right:: Brinyte T28
#brinyte #flashlight #hunting #coyote #redlight #greenlight #predator #gift #christmas
“Mounted it with 1 inch riser on Barnett G350C. Well made and extremely bright. Really like the double beams to minimize shadowing. On off switch is in a position where I do not have to move my hand when it’s on the trigger, basically can think to have it on and it is on. Can’t wait to take it out and try it”
See more details:Brinyte xp22
#picatinny #rifle #arlight #arflashlight #ar15 #Barnett #crossbow #helmet #weapon #shotgun #christmas #gift
Good review shared by Paul👍
Brinyte PT16 2000 Lumens Rechargeable Tactical Flashlight, USB-C Compact Dual-Switches LED Bright Light with Memory Function, IP68 Waterproof for Searching Emergency Camping​:heart::sunglasses:
Usage Experience🎄:
*The flashlight is extremely bright and strongly focused.
*Tactical tail switch can be quickly switched to strobe mode, suitable for self-defense.
*Other tail switches can be soft-pressed to enter Turbo mode for easy brightness selection.
Outdoor Test🎄:
*Low, Medium, High, and Turbo modes all performed well.
*Particularly liked the tail switch and mode selection feature for self-defense.
Learn more: :point_right::point_right:brinyte pt16
#brinyte #flashlight #torch #tacticalgear #lawenforcement #police #duty #camping #selfdefense
Thanks Kyle for sharing~❤️
Brinyte XP22 1300 Lumens LED Tactical Flashlight with Strobe, Low Profile Compact Weaponlight for Picatinny Rail Mount with Built-in Pressure Switch, Magnetic USB Rechargeable,Black
See more details​:point_right::point_right:: Brinyte XP22
#brinyte #picatinny #rifle #weapon #shotgun #ar #ar15 #ar9 #arlight #tacticalflashlight #flashlight
Thanks Tim for sharing~❤️
Learn more:Brinyte PT16
Thanks Saddler Tactical for sharing~!
Brinyte XP22 is a brand-hot compact offering in our tactical series.
Low profile and dual lens design removes the shadow and delivers brighter light, reaching up to Max 1,300 lumens and 260 meters.
Multiple application scenarios, can be used as weaponlight, helmet light, crossbow light, etc.With its compact size, high performance, and ultra-solid build, the XP22 is One of the most feature-packed WML options on the market.
See more details:
Black: XP22-Black
Desert: XP22-Desert
#AmazonPrimeDay #amazondeals #outdoor #flashlight #weapon #brinyte #rifle #ar15 #ar #picatinny
Thanks TRIPLE F. T.V. for sharing~!
If you are looking for a low profile, super bright,high performance and affordable rifle light, brinyte xp22 is the right choice!!!
Learn more:
Black: XP22-Black
Desert: XP22-Desert
15% OFF Discount Code: TPIF1105
#wepaon#rifle#ar#arlight#ar15#ar9#picatinny
