Brinyte PT16 -22% off discout for Amazon Prime
Learn more:Brinyte PT16
21700 Flashlights #SFT40
Super Bright & Long Range Flashlight - Equipped with a High-Intensity SFT40 LED, the maximum brightness is over 2000 lumen. It’s a portable powerful flashlight which is practical for outdoor use and everyday carry. The maximum beam distance is 608m/19944 ft, can light up your whole yard.
Easy to Operate With Dual Tail Switches- You can easily control the light on/off, lock/unlock the light, adjust four brightness levels (low-medium-high-turbo) and strobe and SOS mode through the dual tail switches.
Useful Overheating Protection Feature - If the light overheats, it will automatically lower the brightness to prevent accident . For example, currently using the high mode, if overheating occurs, the flashlight will go through a mode process of high-medium-low-off. This is also reflected in the run time. The run time of high mode in the manual refers to the total duration of the flashlight from high to mid to low to off mode when fully charged.
Memory Function of Front Side Switch - Not opening tail switches, only long press the front side switch to turn it off. When you press the front side switch to turn it on again, the PT16 will remain in the last mode as before you turned it off.
Lockout And Unlock Function - In off state, the front side switch will be automatically locked after 1 min. Press the front side switch 3 times quickly or turn on the light using the tail switch for 5 seconds to unlock it. The light will blink twice to indicate it has entered unlock mode. To lock, you need to press the front side switch 3 times again. After locking the front switch, the indicator will remain dimly lit for 1 min to help locate the torch in the dark.
Easy USB Type-C Direct Charging - The PT16 torch comes with a USB Type-C charging cable, allows you to charge the flashlight directly without taking out the battery. It can be charged using a power bank, reducing the burden of electricity used outdoors.
Smart LED Battery Indicator - The built-in battery power indicator of the side switch clearly displays the remaining battery level in real time: Green (over 70%), Orange (30%-70%), Red (10%-30%), Red flash (<10%), friendly reminding you to charge the flashlight in time, to avoid dilemma when you urgently need it.
