Product: Brinyte XP22 Scorpion
See more detail: Brinyte XP22 Dual head gun light
Emitter: OSL-CSLPM1 *2
Battery: Polymer Lithium Battery (900mAh)[Battery can’t remove]
Maximum surface temperature (℃): 39
Working current: 1.8A(High)
XP22
High
Strobe
Output
400LM
400LM
Runtime
70mins
100mins
Max intensity
13250cd
Impact Resistant
1m
Protection Level
IP66
Beam Distance
230m
Dimension
2.91in(Head Dia)*4.02in(Length)
Net Weight
100g/3.53oz(Including battery)
Inside the box
XP22 (with battery)×1, Different sizes positioning block×1,Screws×2,Magnetic Charging Cable×1, User Manual×1.
【Customer review】
‘’I can say I’m quite impressed, I love the way you have the two lights off center which makes it so nice for putting it on the top rail. I can’t unfortunately hunt with it since it’s illegal here to use white light so I can’t test it to that extent until I figure out a way to get red tint to it.’’
‘’That’s about 150-180 yards if you wanted to know, it’s hard to get an accurate picture with it being dark out the video don’t show how well it’s lit up. It’s a lot better in person’’
Tempered glass lens, anti-abrasion,anti-scratch, and drop-resistant
With overcharge, over-discharge and overheat protection functions Vertical switch design, holding the gun more convenient and stable
Charging intelligent power indication design, with flashing, instant lighting, and other functions Equipped with 900mAh integrated li-polymer battery, more durable and long-lasting
The screw rod is fastened and assembled on the gun body to easily resolve the impact of the gun’s recoil
Using aviation-grade aluminum AL-6061-T6, and military-grade 3 hard anodized on surface
Nice pictures by Tony!THANKS A LOT!!
I actually never thought the Brinyte XP22 Dual head gunlight would fit on a helmet, but then he showed me the rail on the helmet, and I can only say it’s a pretty good idea! This opens up new possibilities for XP22 applications!
If you are also interested,just click it: Brinyte XP22 Dual head gunlight
This Scorpion lacks its sting. Should be a green aiming laser there.
I’d prefer a two stage switch here. Half pressed momentary and full press for strobe.
The Brinyte XP22 gun light has a locking mechanism, but unlocking it is simple. Just press and hold the switch for 5 seconds when the key is locked, and it will flash once to remind you to unlock it. callsign_elvis
Adjustable Rail: Slide the rail adapter back and forth freely to fix the light in the desired position for your specific firearm, making the XP22 compatible with most pistols including subcompacts.
Huge Performance: 400- lumens;230 meter beam;Runs 1.6 hours.Performance comparable to mid-sized weaponlights.
Lock Function: XP22 has lock function, please unlock fiirst after receiving it.In the ON state, press and hold the switch for 5s to enter the locking mode, and the it will flash twice to remind when the switch is locked successfully ;
After the key is locked, press and hold the switch for 5s,then the it will flash once to remind it to unlock.
Convenient Magnetic Charging: Charging by connecting the light directly with the included magnetic USB cable. There is no need to remove a battery or plug into a port that will wear out over time.
Vertical switch design: holding the gun more convenient and stable.
Easy to install: Quick install and removal ; Ultra-compact and lightweight
“I have used this light since it came out. I have taken it out through hours of training in the rain, snow, cold down two -20F, I have dropped it in ponds and streams, banged it into stuff and it keeps working. I don’t know how long the battery lasts, but I have yet run it dead. The On/Off and Momentary is perfectly setup and the switch is in the perfect spot. I don’t use the strobe often, but it is easy to access with a quick double tap. After having messed with many other weapons lights, many way more expensive that this, I will never have another one.”
Thanks Thomas Joseph Mulkey fore sharing review for this light!Come and pick yours:http://amz.do/5ud2gv
The Brinyte XP22 gun light is a powerful and durable tactical flashlight designed for use with firearms. It features high-quality materials, multiple modes, and a rechargeable built-in battery, making it a popular choice for law enforcement, military, and civilian gun owners.
