Yes, RIC pointed that out to me after I posted above. It does work, but the double-click when OFF still engages turbo in lockout - not sure if that's important though, since a double-click is hard to imagine occurring in a pocket or bag.
The 3 second hold to enter or release from lockout is more an issue - I think the sequence should be more robust, because having a button get stuck in the down position can occur in a pocket or bag, I would think.
I purchased this light from MTN Electronics. It is very nice!! I purchased the XHP 35 HI CW version but placed another order for the HI NW version only in stock in tan. Throw from the light is very similar to my TN11sV2 but slighly wider with a little more spill.
The light gets warm quick, especially in Turbo mode. I have never been bothered by this.
With MTN’s advice, I am running the Shockli 4200 mah 26650, 30a battery. Run time is very good in the lower modes and as expected, not so long in the High/turbo. Turbo steps down as advertised.
A tail switch with the side switch would be nice but user interface is simple. Always comes on in low so no memory.
Finish and quality are exellent!
All in all, a very powerful small package! I have nothing but praise for this light and have another on the way!
Please note a double-click from OFF goes direct to turbo, so from OFF, it can go directly to low or directly to turbo. I find the OFF to turbo very useful.
After I smashed one of my Basens flat top down from over tightening the cap, trying to get it to turn on and seeing how I have a bunch of new, used and mismatched 26500’s left over from different mods, I decided the BTU PK26 would serve me better using this format, so I converted back to a spring/ spring set-up. I’m liking this little devil now, it almost met it’s fate by Blow Torch! :rage:
Just for grins, I put a closely shaved E4 1D emitter in it, how about a smooth reflector now! :+1:
I'll keep on say'n it, but the LK 26650 is "the" cell for this light, besides being the best 26650 cell on the planet (low resistance and high capacity), and RIC sells them under a no-name (http://www.cnqualitygoods.com/goods.php?id=2250 ), but available at GearBest as well.
Short tube is for one 26350. It works, for a while, not very well though, or not very long after a full charge, as I reported in the review OP: https://budgetlightforum.com/t/-/41027.
Sorry Tom, I don’t follow this thread that much, must of missed it. But it’s the shortest 26650 I had, they still work in series and it gave me the idea to use the other wise abundant surplus I have on hand!
No prob, a good improvised solution. But for the general user, just want to make them aware the LK 26650 is available off the shelf and fits about perfect and performs great in this light.
Oh must of missed this too…. a short tube 26350? I noticed last night playing with it, that at 4.08volts the light jumps out of Turbo and only lets you use 4 levels, which is fine by me? Tried 3 different batteries and all failed holding Turbo at this voltage? Any ideas why?
Ohh! Even on a 26650 at 4.08V or below? Yikes! Might not have tested that. Oh boy... I noticed it in the 26350 because it drains so fast. Should have done a full discharge test . I'm pretty sure the amps draw increases as the cell drains, to get more power - regulation kicking in. I guess there's some sort of limit on that draw though.
I was hoping RIC would come out with an improved driver that I could swap in. If not, I'd probably end up doing my own mod with a normal FET+1, or triple, and go with a dedomed XPL - it still throws decently for an OP reflector light in a small package. I invested in full trits on this one because I really like the host, so I'll make it work well regardless.
If he's adding springs to the PK26, then the changes are potentially more major, and a future driver update might not be backwards compatible (size, mount, etc.).
If RIC could chime in on this -- any idea whether an improved driver will be available?
