BTU PK26 CREE XHP35 20W MINI Pocket Rocket
BTU PK26
http://www.cnqualitygoods.com/goods.php?id=2244
Specifications:
Material: Aircraft 6061 Aluminum Alloy ; Thick HAIII anti-slippy Finish
Color: Coffee Black HAIII / Champagne Yellow HAIII
Emitter: CREE XHP35 HD / HI CW / NW
Battery: 1x26650 / 1x26350 / 1x18650 / 1x18350 / ; Recommend High drain 15A or 20A battery for this light.
Reflector: OP aluminum Reflector
Double-Side AR Coated Glass lens
Trits slots: 1.5x6mm trits slot x 7 ———— Green / Blue / Red / Orange / Purple / White / Pink
Dimension:
110mm x 41mm x32mm (26650 version)
81mm x 41mm x 32mm (26350 version)
Weight: 135 gram
UI:
  1. Press 0.5S to turn on ; Press 0.5S to Turn off ; Single click to change modes;
  2. Modes: Low Low1% >Low 10Midium 35>High75; Double click to Turbo 150 1.5A 20W 2000 lumens, Click again back to previous mode.
    3: No memory , always start on Low low ;
  3. In any status , double click to access Turbo ; Temperature control— Turbo mode will step down to Previous mode after 120 seconds
  4. Digital Lock-out function ; Tailcap Lock-out Function; Can lock the flashlight to avoid acciddental turn-on when putting it in pocket or bags.
  5. Digital Currenct Regulation ; High efficiency
  6. Temprature protection. The light on turbo mode gets hot very quick,if the light get too hot especially in hot weather, the flashlight will flash and step down to lower mode to protect the driver.
Advanced Battery power energy indication function:
Battery power Indication A:
Full power to 3/4 power —- Switch LED turn Blue
2/4 power energy —- Switch LED flash some times
1/4 power energy —-Switch LED turn Red and flash some times
Battery Low-Voltage protection:
When 1/5 power energy left, the flashlight will flash some times ; Then the flashlight will step down to Low Low mode to extend the runtime.
Included Accessories: Extension tube; SS clip; Flashlight bag; O rings ; Packing
Trit link:
http://www.cnqualitygoods.com/goods.php?id=2010
For 26350 battery, It’s 5usd each.
As we only have 56pcs 26350 cells in stock for the moment. First 50 orders will get 1x26350 for free. We are told by battery supplier that Next batch of 26350 will get ready in 10 days.
USA Customers can contact RMM to pre-order this light. It will be faster to receive.
Here is his website:
Ric
Wow this looks very interesting! Really cool with the option for trits.
Awesome! Any GB on this? :stuck_out_tongue:
what a looker!
If you ship this as fast as you did with my Jax order (next day tracking number in the mail) its only the customsthat delays people from holding it(argh French custom is holding the jax now :wink: )
That sand colored next to a Meteor M43 should make a beautifull pair
look nice.
I wont be ordering from CNqualitygoods again as they never ship 2 of my orders and deleted both of my accounts then I had to go through paypal dispute.
Will patiently wait for other vendors for purchase
For some reason the pics from cnq never loads on my screen, and the page is always down as well, anyone else?
It works fine with chrome!
OMG!
That is an amazing flashlight! Its performance looks like it matches its looks!
I never thought such a beast would ever exist… But it does!
Slightly out of my price zone though… :frowning:
Impressive light!
Same here - for some reason my adblocker was blacklisting their domain! Had to whitelist it to resolve the domain.
I am using pi-hole on a raspberry pi and some list out there must’ve included the domain?
From Site: “Appearance patent protected, any copy will be prohibited” <=== Good luck with that. The Irony……
But the images never show no matter what device and network in on…. Tried with PC iPhone and android tablet… Weird!
Probably they made it available to certain regions only, not sure.
Can some one reupload the pictures on another image host? Thanks!! :smiley:
What a beauty, I spent my flashlight allowance on an L6 or I’d be in :heart_eyes:
THAT is nice!
Which driver is inside ?
Regards Xandre
Take a look at these. http://www.cnqualitygoods.com/goods.php?id=2249 and http://www.cnqualitygoods.com/goods.php?id=2248
Looks like I can finally upgrade my old JM07.
Beautiful!
Gagh! Amazing!
Real Nice! To put the size in perspective, it's a 41 mm head diameter light - lot of lights in this head dimension category.
The Eagle Eye X6 is 137 mm in length, SolarStorm/FandyFire K2 is pretty short at 129 mm, the NiteCore EA41 is 117 mm, and the Lumintop SD4A is close at 112 mm - this PK26 w/26650 is 110 mm, so even with the big cell, it's a compact size.
Thanks,that is what I think,too.
Regards Xandre
