Ikon in post #42 (from this thread) mentioned that the TK75 tube might be an easy mod candidate
I keep thinking about a long/heavy modded Shocker (4S3P 18650) with triple XHP35 HI (7.5A @16.8V for about 1.5 hours total run time). But at that point, a remote pack would probably make more sense.
There also exists aluminum tube stock with similar ID & OD dimensions to the Shocker tube. The stock Shocker tube could be bisected and a section could be added. If threading isnt an option, a step could be cut into each tube section on a lathe and then compression fitted and staked. It would look pretty good with a polished center.
Hi,
Thanks for your response.
I´ve ordered one Extender Set for TK75, but this is with battery carrier for about 30€. The Carrier itsself costs about 19€, so tube alone would be at 10-15€, but not available alone.
You are right, I was looking for a alumium tube a long time ago, but I´ve no turning machine, so it´s difficult and expensive for me to fit it.
Thanks for the update. Im not sure that 2 x TK75 extension tubes might be a better option. At least you have a great starting point. Maybe you could PM Icon and ask more details about fitment on both sides of the TK75 tube and its interface between the BTU head.
Hi. I’ve canceled my order for TK75 extender because it doesn’t really fit.
Cnquality and banggood doesn’t sell tube of magic scorpion separately.
I will order a aluminum tube 50x2mm (inner diameter 46mm).this would be best and than mount It with screws because I can’t make a screw thread myself.
Thanks.
That might be the best option to avoid frustration in trying to modify Fenix threaded parts to work. How many cells, which emitters and driver do you intend to use for your mod?
This is off topic, but I would like to use three XHP-70, N4, 5000K on Sinkpad II in parallel on a copper plate, with a LD-3 Driver (15A at CC, DD maybe 22A) powered by four LiPo-Packs (each 2S, 1300mAh) in parallel.
I think XHP-70 have Vf with 7,0V or so and LiPo-Packs doesn´t have much Voltagedrop at only 5,5A per LiPo, so maximum Output will be there for a longer time ;).
Heatdissipation will be biggest Problem…
Although rectangular in shape, there are several listed on ebay that would seemingly do the job. For 3 x XHP-35, you would need one capable of safely sustaining 7.5A @ around 14.22V. Since these are cheap Chinese drivers, Id look for one capable of sustaining 10-15A at that voltage (to allow a margin of overhead to reduce the chances of failure). At this point, a box-style flashlight with CPU fan-cooled heat sink makes far more sense than the typical passively cooled long-tube flashlight. A large battery pack would also reduce the overall dimensions and provide full-power, long, continuous runs without overheating.
