As above.
I know that I can get the L6 in host form but any suggestions for any other cheap 2 x 26650 lights to mod or hosts ?
Yezl Y3
Thanks I will check it out :+1:
The driver even supports 6v emitters, you could double the output by just dropping a XHP50 in there. Mine has a MT-G2 making about 1,800lm. Not the best build quality or anodizing but cheap enough to play with.
Have you thought about using 2x 26350 cells in single 26650 hosts?
Not really as it would mean me specifically buying another sized cell, where as I have plenty of 26650 cells.
The only place that I can find the Yetzl Y3 is Fasttech for $36 (with extension tube), is that about right ?
For a few dollars more ($40) I can buy an L6 host, which I would imagine is a better build quality.
Then again for $65 I can buy a complete L6 & with a code I can probably get it for $60 ?
No wonder the “S70” clone at $19 didn”t happen :person_facepalming:
Even cheaper than 50$ with a code from M4D M4X:
That is very cheap for such a great light.
I wonder if M4D M4X could do a code for the clear L6 ?
The Convoy L2 is a great host,also.
Regards Xandre
