Hi All,
So, This is not exactly a flashlight… but it is an LED light system. I’m a biologist, so you all know more than I regarding LEDs and how to use them, so…
(Mods, please move this if it’s in the wrong place. This was my best guess)
It’s been a while since I have built anything fun, so I decided to try my hand at making a good blue light DNA transilluminator. Commercial versions of these are available, but small/cheap ones run over $500, and ‘good’ ones run closer to $2000. These systems are effectively just LEDs with the proper wavelength mounted under a diffuser and a glass sheet, then a filter over the top. All scientific equipment is ridiculously marked up, but these seem particularly expensive for a box with lights in it.
Yes, I could just buy one. I am doing this more for fun than any real need. I thought this forum might have fun thinking, designing and testing this contraption!
The concept:
DNA is separated by size within an agarose gel matrix and stained with a fluorescent marker. To visualize the location and size of DNA fragments within the gel, it is placed on top of the transilluminator, and light of a specific wavelength is passed through the gel. The fluorescent marker is excited by shorter wavelengths, and emits a longer wavelength. The gel is viewed through a long pass filter allowing you to see the emission wavelengths of the marker while blocking the shorter wavelengths used for excitation. (The somewhat obsolete versions of these use UV (301nm) as an excitation wavelength end the markers emit green (603nm) light. These don’t need an additional filter for viewing (because we can’t see UV light) however, since UV is extremely damaging to DNA, using to visualize important samples is problematic. Blue light is non-damaging and the applicable markers are safer to handle).
Blue light transilluminators use a marker with an excitation range of about 450nm-550nm with a peak at about 497nm and an emission range of about 490-670nm with a peak around 520nm (https://www.thermofisher.com/content/dam/LifeTech/Documents/spectra/images/7567dna.jpg)
The “long pass filter” that is normally used is a piece of acrylic (color code #2422) which is very efficient at blocking everything below about 540nm (it’s just a piece of plexiglass, but it works really well for this purpose and costs about $10 sq/ft).
So, (finally) here’s what I am trying to build:
1) An LED panel able to provide bright light peaking around 490nm. What are your suggestions for specific LEDs to use in this panel? The illuminated surface will be about 8.25”x8.25” inches, so the panel should be slightly smaller than that. Are there inexpensive blank PCBs that big on which to solder a bunch of LEDs? (I can’t find anything suitable for sale without spending a lot on a custom PCB). Are there other options for building this panel? Shoot me suggestions!
2) A short pass filter to clean up the raw LED light allowing for nearly 0 transmittance through the long pass filter used above it. This is necessary unless the LED outputs very clean light with nothing above 540nm but most LEDs in this range output some higher wavelengths, even though their peaks are lower.
3) I already have the long pass acrylic filter. This component is sufficient, so I don’t really need suggestions for this (https://www.eplastics.com/img/Plexiglas%202422%20TP%20Amber%20Wavelength%20Chart.jpg).
I am decent at building electronics and soldering, but I really need suggestions on specific LEDs and/or filters to use for this purpose. My first attempt uses a cheap “ice blue” LED strip from amazon ($15) and a piece of acrylic #2114 ($10) as a short pass filter/diffuser. This setup results in a LOT of very, very blue light with great diffusion. When the long pass filter is placed on top, the blue is completely blocked (it looks black and dark -i.e. perfect). However, I think this setup produces closer to a 450nm peak. This MIGHT work (I have not tested it with actual DNA marker), but it’s not close to the optimal excitation wavelength, so it will not be very efficient, and will not work well for viewing very small amounts of DNA.
How do I get this rig to output closer to 470nm-490nm while still being completely blocked by the long pass filter and still be relatively inexpensive?
I’m in the process of building a spectrometer to test this contraption… Maybe that should have its own thread?
Again, let me reiterate, that this project is just for fun. If you aren’t here for a fun thinking/design challenge, please be nice anyway ![]()
I’ll post some pictures soon to show what I have so far and as this project goes forward.
Let’s see what you’ve got!
Thanks!
