I cant tell you much other than its about 5w and 12v forward voltage and its mounted on a 20mm MCPCB.
I want to replace it with a warmer tint.
I have no idea, it is very small for what looks like a COB led, only about 5mm diameter.
I dont recognize this LED
Are you sure its a 12V LED or just the light itself is for 12V?
if its true 12V it should have 4 separate LEDs inside and its forward voltage should be around 12-12.5V at 5W
but for 5W 12V LED a Cree XT-E High-Voltage XHP35, or XHP50 on a 20mm star should be a good replacement
https://www.digikey.de/product-detail/en/cree-inc/XTEHVW-D0-0000-00000HCE7/XTEHVW-D0-0000-00000HCE7CT-ND/3927156
Thank you pals.
You can just about make out there is several very small LEDS behind the phosphor layer
Thanks for the recommendation Lexel
