Skip the junk that look like corn cobs or Christmas trees, and just radiate their output spherically. That’s not how such light fixtures function.
As any flashlight enthusiast should understand, they function by using the reflector to direct the output of the emitter in the desired fashion, and with focus, not blasting stray light everywhere in an attempt to overcome fundamental flaws. A flashlight with an XP-G and the right reflector is going to be a much more effective animal than one with a bunch of bare, cheap T-1 3/4 emitters acting like a mule.
These look simple, and don’t look sexy or like they’ll ignite eyeballs, but they are designed to focus their output on the reflector, and thus work properly, if the shape of the fixture is suitable.
https://www.amazon.com/SYLVANIA-Bright-Ideal-Lights-Contains/dp/B01A77TT7U
Two heat-sunk high-power emitters approximating a point source like the original filament, vs a bunch of cheap SMD emitters with no regard or attempt at focus.
Philips actually had similar designs on the market before anyone else did, but they’ve seemingly discontinued them, and now only peddle the junky stuff.
But keep in mind that even these types aren’t optimal if the “bulb” and its emitters aren’t indexed in the right relationship relative to the reflector bowl when set in place. If the CHMSL is short and wide, but the bulb ends up being oriented with the emitters facing the top and bottom, it’s not going to work in the best fashion.
Lastly, also keep in mind that red emitters need to be paired with red lenses.
Not white emitters, which result in pink output, which ≠ brake lights and doesn’t conform to universal signalling protocol.
But I think you were already aware of that.
