Can RTV silicone (aka silicone caulk or adhesive) be peeled off teflon after its cured fully? I’m looking for it to be removable.
Could being completely surrounded by teflon slow the cure rate?
Not sure if neutral (non-corrosive) or acidic would be better. Teflon would be thin, 1mm max & silicone 1-2mm.
About the only way to stick stuff to teflon is to etch the teflon first. They used to use metallic sodium dust suspended in THF or anhydrous ammonia to do the etching. Now there is something a little less dramatic.
Most (maybe all) silicone products use moisture from the air to cure. Moisture has a way of working it's way into everything. If you seal it in real good, it could take a very long time to cure.
