I have a TMart hd2010 and I ended up with a copper pill for it. I just got around to trying to mod the light and the threads on the pill are too small. Can somebody please measure the Outside diameter at the threads for their HD2010 for me. I am just wondering if my light has a different size from everybody else’s or if it is the pill.
None of the HD2010 lights are standardized. The different brands have different threads and I have seen them change from one run to another. I do not know which one might fit, but there is a thread here somewhere that tells and someone else will come in and tell you.
Old Lumens,
The one I have is the Tangsfire from TMart. You had a thread that where your video mentioned Ryan’s pill fitting them. That was the reason I went with the Tangsfire and not another brand. Oh well.
OL also said the same brand can change from one run to the next. Read where someone said he had a BLF EE X6 from the first run and one from the last run and the tail caps were not interchangeable.
Yeah I know. Was just hoping maybe it was the copper pill and not my light. It kinda kills my whole plan with the light since it doesn’t fit. If somebody that has one of the copper pills can confirm theirs is Xmm across the threads, I’ll just see about getting one custom made. I want to drive a XP-G2 at 5a using 2 26650’s. I already have the extension tube. The plus to the copper pill I have is it has a 20mm driver opening, but none of it does me any good since it doesn’t fit. If the pill is just undersized or for a different light, then I was going to have some extras made when I had mine made. If the copper pill is the right size and my light is just different then I’ll just get the one made for my light and be done with it.
for the record...I have a black Tmart Tangsfire hd2010 and a Tmart no name black 2010 that have identical pill threadings. But the Gray-colored 2010 (also from Tmart) has different pill threadings and it's tailcap will not interchange with the black ones..
The yezl Y3 extension tubes screw onto mine with no problem.
