Can/ will this be done?
Build one yourself with some cell holders and a CC-CV buck converter.
I have no experience with this model, but apparently the Liitokala Lii-S8 can do 4x 2A.
It is an 8 slot charger, but with all 8 slots in use, it can only do 1A per slot.
By the looks of it, I see a current button, you can manually set the current, so you can hopefully ā€œforceā€ the charger to charge with 2A, instead of the charger deciding what the max charging current is.
It’s relatively ā€˜cheap’ on Aliexpress, so might be worth a try.
There is also the similar looking Lii-S12 (12 bay) charger, but that can’t do more than 1 amp per slot and I think you also can’t manually sellect the current.
CC/CV charge without end of charge detection is (very) harmful for the cells unless you only charge while watching over it and manually terminating the charge at the correct time.
