Can you share the runtime of your tactical flashlight.
I have a small test with my favorite tactical flashlight: Brinyte PT18 Oathkeeper
I would love to see the results of your favorite tactical flashlight.
Is a tactical flashlight one that has a button that doesn’t make a click sound when you turn the light on? So that people cannot guess your location?
In the dark, I think light is easier to detect than noise
Tactical seems to be a requirement for this review. What distinguish a tactical flashlight from a non tactical one?
And more importantly, what is particular in the tactical mode that could influence the runtime?
Sure thing,
Here are the run times of a Streamlight Protac HL 5-X
Which I reviewed here:
I think my Lumen measurements are a little low. I am still working on my Lumen Tube.
Run time on High First 10m
Run time on high
All the Best,
Jeff
An extremely impressive number. Can you please state your room temperature?
I didn’t make note of the room temperature when testing the light.
But considering the date, it was likely to be about:
74F-75F which is about 23C-24C.
I run the tests in my office in a commercial building so the temps are never very warm or cool.
I didn’t record any thermal measurements during the run time tests.
My new test setup will hopefully do that.
All the Best,
Jeff
I tested the Armytek Doberman Pro:
https://www.armytek.com/flashlights/models/dobermann/armytek-dobermann-pro/
A previous, excellent review had tested Turbo 1 and Turbo 2:
So for my test, I decided to test the runtime of the the 150lm medium mode using a Keepower 3500mah:
The light is rated for 150lm x 10hrs.
My results were pretty consistent with that.
It maintained full brightness until here:
At which point it flashed twice, then dropped down to its next lowest, 30lm mode.
It then maintained 30lm for another hour, at which point it dropped into moonlight mode and I ended the test.
Overall pretty excellent runtime.
I plan on re-running the test later at 350lm.
I don’t think I own any lights that qualify for “tactical”
To me, that means:
- forward-clicky,
- tail switch,
- starts on high
And I don’t have any lights to meet the first two requirements.
But, I have a ZL SC62 and SC62w, which should do pretty well on the runtime front. I’ve planned to eventually do an XHP70.2 boost driver single-celled build, which I imagine would do pretty well, even better if done in 21700 or 26650 size.
Other than that, I have my modded L6 which should be able to run for… Over 36 hours at a bit over 150 lumens. But that’s theoretical. And then if we’re really talking about runtime I’d want to start with a Q8, throw XHP70.2s in it and an efficient boost driver.
So yeah I guess it all depends on what you mean by tactical
You forgot the most important part. That aggressive attack bezel! lol.
