I think most people understand how these decisions are made, but for others I will try go over some basics.
In looking through Sofirns lights with Anduril it seems they are all 3v units, no 6v. When it comes to using a UI such as Anduril a company typically has to pay a small fee to have someone familiar with the UI to design a driver and tweak the software. I know Toykeeper, Lexel and Texas_Ace have done this. It’s quite a bit of time they have to invest so they can’t do it for free.
May theory is Sofirn invested in Toykeeper to build a 3v Anduril driver for them and they then used that in several 3v lights. It makes good financial sense. (make a profit)
They invested again in Toykeeper to make the lantern light driver because they saw really high interest and would recoup the investment. (make a profit)
Sofirn would need to invest again to have a 6v Anduril driver designed. I don’t think they have very many 6v lights. I only see the SP70 and TK70. If they don’t think it will sell enough units to make up for the investment (make a profit) then the higher ups will not invest in the new driver.
Keep in mind Sofirn has their own driver and UI designers in house they are already on salary. It’s hard for them to pay an outsider to do that same work.
Also, it could have simply been that Toykeeper did not have time to do the development. You never know. I’ll ask her. She might have some insight into the SP70.
There used to be a 6V driver in the SP33, but version 3 unfortunately uses a 3V XHP50.2. I wonder why that is. Plus Barry announced a Q8 Pro, which would be another candidate for a 6V XHP50.2 (and Andúril) if I’m not mistaken.
OTOH, Sofirn has a nice proprietary UI since the C8F. With some minor tweaks and debugging I’d prefer it to more complex UIs.
Anyway, thanks for investigating the situation :-).
The SP33 has always been 3v input (single battery). The Boost driver with 6v output is a completely different driver design and would not be compatible with the SP70/TK70.
The reason they switched from the Boost driver to a 3v FET driver was because Cree came out with the 3v version of the XHP50.2. The 3v FET driver is cheaper to make and has higher output so I could see them making it. (I prefer the Boost driver version myself)
I’m not familiar with the Q8 Pro. Would it use a battery carrier to get 6v? In theory they could make the whole light 3v.
The only thing in SP33 V2 that caused some confusion to some customers was the UI of the boost driver. The lower the voltage was, the less brightness modes you could trigger.
SP70 however does not boost its voltage from a single battery but simply uses two batteries in series (= 2x 3.7V) to drive the 6V XHP70.2. For those of you who are skilled in driver modifications, you may want to try Convoy's FX-31 (L6) 2S/3S buckdriver in the SP70. You will probably gain more runtime and efficiency but less maximum output. I suggested Sofirn to have a look at Getian's FC40 LED that I discovered on Simon Mao's Convoy thread. They seemed very interested but first attempts to source this special neutralwhite HighCRI version were not successful. Maybe in some time they can also get access to those emitters.
XHP50.2 3V was chosen because - IIRC - it was cheaper to source and more powerful (3,500 over 2,500 lemons). Last time I talked to Barry I heard it was difficult for Sofirn to get any XHP50.2 LEDs and so multiple flashlights suffered significant delays (SD01 Pro, Q8 Pro). Q8 Pro was meant to be using 3V XHP50.2 LEDs, i.e. same driver design they used for Q8.
Agreed. The tint shift is an issue especially with the more neutral tints (< 5.700K), unless you fancy greenish beams. :-D
If they were open to utilizing 6V/12V LEDs, I would like to see a quad array of Luminus SFT70 in their Q8. That should result in both more throw and lumens.
My Olight R50 is really green, but everywhere in the beam. Much better than the rainbow pattern. Have not seen the SFT70 yet. If it’s as nice as the 5000K SST-40, I’d be in.
Edit:
It would have been easy and inexpensive for Sofirn to just bring out a Q8 Pro ‘lite’ using 4 SST-40. You know my thread about producing MCPCBs. Besides designing this board, a small modification to the reflector is all that would be needed. It’s beyond me why Sofirn rejected this idea. Little investment to get into the market of significantly more powerful lights. If I’m not mistaken, we’re talking about around 9000 lumens here and few dollars more in the final price. A no-brainer.
Yep, Infineon OptiMOS5 or Vishay SIRA20DP/SIRA60DP would be nice Mosfets in the SP70 or other Sofirn flashlights. OTOH, I doubt it's worth all the efforts for pushing a single XHP70.2 to its very limits. 8000lm equals to probably 20amps which is close to the absolute maximum for this emitter. Maybe Sofirn could try a linear driver with constant current regulation like Noctigon K9.3? It would be nice to have lets say 6-8A regulated which could maybe maintained indefinitely with such a big light, see Convoy L6 with the FX31 buckdriver for comparison.
Hi Lex, Ive seen you mention the FX-31 driver multiple times but cant seem to find one. All I could find is the FX-30 driver. I have a 3S 26650 light that Id love to mod with the driver you mentioned. Can you please post a link or where I can buy?
