Canoe Bow Light....DESIGN HELP REQUEST
Howdy,
I am in need of building a light for the bow of my canoe for night racing on rivers here in Texas. I’ve got a Maglite mod I’ve done in the past that works well, but it’s big and it’s heavy. I want to cut weight and size. I’m a cnc guy that can make just about anything. What I’m not good with is electronics.
Here is where you come in should you choose to help me with recommendations.
I would like to build something that is an inch or less in diameter. I’d like around 400 lumens. I’ll run wiring out of the back to a separate battery pack that will be mounted under the bow deck plate. The battery pack will hold 8AA lithium batteries (so 12V), and will need to be regulated. I’ve been out of the mod game for far too long so I’m not sure where to start. I’ve seen some Luxeon star setups with 3 leds on them and I’m sure there is some sort of lens that would work with something like that, though I’m not sure if that is what I should be considering.
I welcome any and all suggestions. I’ll end up doing a build thread on the project once I know what I should be using.
Thanks for you time and your help.
Jeff
How bout mounting a common bicycle light up there? You could put the battery pack in some kind of waterproof pelican box, but that should be pretty easy.
Welcome to BLF!
Sounds like an interesting light you want! Cant really help you but sure others will pop in to add their lumens to those of RobertB
If I could draw this, I would…
If I had access to CNC & some Al, I think this might work:
I’d make a cylindrical “pill”, threaded all the way on the OD, with a 20mm * 3-4mm recess in the front for one of these:
And a 17mm recess in the back for one of these:
And holes to pass LED+ & - wires through.
Then turn a thin “cup” with the ID and threading to match the OD of the “pill”, with a 20mm ID hole in the front to retain one of these:
I’d find a way to put an O-ring there…
(you may want to cut cooling fins on it, but nothing radical — they draw spiders!)
And I’d make some “base” threaded in the ID to fit the pill’s OD which would give you a flat surface & screw holes for attaching that “base” before screwing the “pill” and the “front cup” down into the “base”, which I would actually mount at the point of the bow, not above it. (Always minimize glare!) I see it as screwing the “pill” into the “front cup” first to secure the TIR, then screwing that into the “base”. Another good place for an O-ring.
(basically, a minimalist flashlight head the size of an S-series “roll of coins” light head, but with the external battery pack & remote switch…)
Speaking of switch, if you soldered all connections with 22AWG wires (for the possible 2.8A), connecting the B+ connector on the driver to the battery holder, then from the holder’s B- to a clicky switch back where you are (another CNC opportunity here), then another 22AWG run from there to the Ground ring of the driver, you’d get Mode Switching (you just might need SOS in your canoe someday…) like any flashlight. With the switch under the gunwale by your hand.
You could wire the battery pack 3S3P (I’d make two & keep them both charged) & get some decent runtime in the lower modes, with a handwarming High for the Dire Straits.
Basically, you’d be turning your entire canoe into a giant S-series clone. You could substitute a 60° TIR for a broader, smoother, less throwy light… The 15° I linked is in my EDC S5 clone right now & I’m starting to like it a lot.
That’s what I think. When they invent a mind-reader helmet I’ll show it to you! :wink:
Thanks for you input as this is what type of setup I’m considering size range. I see that the regulator you linked only goes up to what I believe was about 4.5 volts maximum input, but I’d need to go back and double check to be sure. Got one you can recommend that can handle 12v input?
I will mostly likely go for the 15degree lens as we wear headlamps too which gives us our side to side viewing. The light I want to make is to light up anything in front of where the boat is pointed, and the further the throw the better.
One other thing I didn’t mention but would like to incorporate is a push button switch that can do some of what you’ve mentioned in your post. I would like to be able to turn it on/off with 2 power modes. Medium, and high. I would like to power on and it be in medium output mode and then press again to get high. I guess power off would be holding the button down until it turns off. This switch would be tied into the light and mounted by the bow paddler just as you suggest.
Anything else you can chime in with is appreciated. I’m an electrical dumbass. If I know what I need, I can make it. It’s just figuring that part out which gets me frustrated.
I was a little premature with my post above. I see that the driver you recommended has mode groups which is great. I guess I just need one with a higher input voltage.
Just out of curiosity, why 12v?
You said you have an 8*AA battery holder. That means to get 12v you’d wire it 8S1P. Eight batteries “long”, and one “wide”. You’d have Voltage but at the cost of Runtime.
By rewiring that same holder to 3S (i.e. 4.5v) by 2P you’d have enough V to run the driver (I was assuming that’s all you’d be doing with the battery pack), with twice the capacity, and 2AA extra space (14mm*50mm * 2, for mounting, storing extra batteries or an emergency 1AAA flashlight, whatever).
If it were me, and I needed to put a headlight on and needed 12v for some accessory (a friend & I made an electric boat from a big canoe called a “Thistle” once…), I’d make a 2nd pack for the 12v & keep the light isolated.
But that’s just me.
And most of the 12v LED drivers I can find (for car/motorcycle/boat use, e.g.) are just DC-DC converters & would need re-engineering to get dimming or other modes.
TTFN…
Dim
Hey Dim,
Thanks for keeping me on my toes. My current setup with my Mag head conversion is running off 6 volts. I have two battery packs that each hold 4 AA batteries and wired in series. Each of those are wired in parallel (for the extra capacity). In my head I thought 8 batteries, 12 volts. I do have a pack I wired up to 12volts, but it’s running my bilge pump which is probably why 12volts popped in my head initially.
You have a driver in mind you recommend for 6 volts since I already have a pack made up this way? Any particular switch you’ve used that you like and would recommend? I’ll mount it as you suggest (under the gunwale by the bow paddler.
I don’t know, bud… It sounds like we may be drifting toward the X-Y hydraulic here…
I was just thinking about the time I’ve spent in canoes & john boats at night, and what would this flashlight in my hand look like at the bow. With a TIR, these S-series lights can give most P60 clones some serious heartburn, from a head about half the size of your thumb… It seemed like an interesting challenge. I don’t really work with any 6v drivers, though…
I think I would pull one of the 4S, if it were me, to leave 4.5v which is all the driver can stand. Leaving the 2 packs in parallel would get you through the night, and the 2 “extra” batteries could be left on the bank, to save weight, or added to the bilge-pump pack if you’re messy.
Or… If you’re just diligent in carrying a bilge pump & don’t really need it that much, you could pull all your weight into the middle of the boat (where I’d expect the bilge pump would be) by just leaving the 4S packs on the bank (or using them to parallel the bilge-pump pack), attaching one of these 12v-5v DC-DC Converters to the bilge pump battery pack, so the 5v output feeds the switch end of that wire to the bow. You’d want to definitely use Quick-Disconnect connectors (or you could just find a USB Female connector instead of the QD & not have to hack the DC-DC converter… plus, that would let you charge your cellphone) to be able to drop as much Voltage as you can to keep from cooking the driver. Even with thin wires & QD connectors, you’d be lucky to drop .5v, meaning the driver is likely to get mucho caliente for the first couple of minutes of running.
Or, you could add a courtesy light to your switch housing to soak up some of the excess voltage… Just thinking out loud…
As to a switch, I use this guy’s smaller 3A switches in the flashlights I build, so this 6A one should please you. You’ll need a housing, of course, but that’s where your CNC comes in. The dimensions are provided in the ad. It seems to be a Momentary-ON, meaning you’d partially press it to blink through the modes, then when it hits the mode you want, just press more firmly to click it in.
So you’d go from the 12v pack, to the DC-DC converter, to QD (or USB) connectors, to the switch, to the bow & only have the light package in the bow. That would be clean and neat.
And bring extra beer, because you’re going to really piss off everyone who gets in front of you! :beer:
You’d be turning a Convoy S5 into a Canoe S5!!
Call it “CanoeFire” and we’ll be seeing them on Alibaba with a 100,000-unit MOQ within weeks!
Sorry, if I don’t pun it, who will?
Here is one I just built up for a guy for the Texas Water Safari race.
Light head - 1 1/2” wide x 2 1/8” long x 3/4” tall aluminum
2x Cree XM-L2’s mated to Ledil Regina reflectors
Current regulated at 800ma’s
TrailTech waterproof connectors
10 ft jumper cable w/inline switch back to battery packs
12x AA battery holders (6S2P) using self fusing silicone tape so seal up the packs
GoPro mount
Nice setup. Who’s it for? I might know them. I’ll be Team Captaining again for the TWS. This will be my 4th year as a TC. I’ve paddling it once (19 years ago) and plan to paddle again next year for my 50th birthday.
How is it mounted? The 400 lumens is the easy part but flood or spot? An S2 or A6 triple mounted with a modified or custom mount and with the battery tube and switch replaced by a new glanded cap with a cord running to the pack In the long run rechargeable nimh’s will be less expensive. A self contained unit with a longer 2 X 18650 tube and 1 A buck driver would be even simpler and allow for 6 hrs run time. Would just need to educate on the use and care of liion cells. If 3 hrs or less is all that’s needed a single cell host would only need the mount and mod to a triple which could be had ready made from Mtnelectronics. Changing to a triple eliminates the glass which could break going from hot to wet or switch to a polycarbonate lens over the stock reflector.
I’ve canoed a bit, water will be an issue. You might even want to look at dive lights like this one http://www.gearbest.com/led-flashlights/pp_35807.html
Even dive lights require regular attention to the seals and a relube. A tube style dive light or canister cave diving light would be nice but not budget friendly. Lupine makes outstanding but very expensive mtb lights with remote batteries as well.
