Glad they are working for you!
Though the link to your picture seems to be broken for me.
Hmmmm, I don't know what happened. Was working, now it's not. I reinserted the picture and added a link to the photo in case the picture stops working again. Is that working for you?
Yes that worked. Looks good!
I found this case for the Sony SRS XB-13 bluetooth speaker that fits perfectly well with the LT1S. It has a space below too that fits the included cable very well
I took a gamble on a Sony SRS-XB10 case from AliExpress.
While it isn’t perfect (no separate compartment for the cable), the fit was good and it was really cheap!
Here’s one listing, but there are plenty of them for around $5 on AE: https://www.aliexpress.com/item/33007801087.html
Link?
I like this better but in case it doesn’t come thru. Page Not Found - Aliexpress.com
I’ll give that one a try or this one. 4.68€ 60% OFF|Ltgem Hardcase kompatibel mit Sony XB10 / Anker Sound core Mini & Mini 2 tragbare drahtlose Lautsprecher Aufbewahrung tasche (nur eine Tasche!)|Lautsprecher Zubehör| - AliExpress
They used to have the small one only for sale. Sold out before I could purchase.
If this fits, seems to be the best option to add to your website
If anyone cares, mine came in and I can fit a flat usb c to usb c cable, dual usb c & lightning charger, flat lightning cable, a usb c lightning cable
All I need now is a huge power bank or solar panel to power/charge everything in an emergency.
I guess that is good, but how well does it fit and protect the LT1s ?
If anything, judging by all of the extra stuff you can fit into it, the case might be bigger than what I am looking for.
Being able to hold the cables and chargers is not that important to me. I have other places to stash those.
But, having a case that takes up as little room as possible is important… for what I want anyway…
I messaged Barry a while ago when looking for a case. He found something similar to what I asked him to try. Looks like he found the one with a a grey lining, I prefer black but it will work the same.
Protects it as well as the cases people use for LT1. The Tycka lens pouch or this would be the most compact. Amazon sells this for a little bit more. 4.68€ 60% OFF|Ltgem Hardcase kompatibel mit Sony XB10 / Anker Sound core Mini & Mini 2 tragbare drahtlose Lautsprecher Aufbewahrung tasche (nur eine Tasche!)|Lautsprecher Zubehör| - AliExpress
I have a lens case that works OK. A bit of a tight fit, but OK. Was looking for something better. But you are right, the lens case is about as compact as I can get. Just not the ideal form factor. A tube shape is inefficient in the use of packing space. Also, it has more padding than is really required.
For $6, I will probably try the one from Sofirn. Fortunately, I am not in a big hurry.
