Recently purchased a moto G6 which has a 3A max charge capability. The battery is 3A hr, so this is basically 1C peak.
This webpage says a full charge takes 109 minutes to go from 0% to 100%.
The phone definitely gets warm when charged with 3A,I was going to try to measure temperature rise of the case but I can’t find my thermocouple.
Anyway, I am thinking I can cool the battery (enough?) to counteract the internal heating my charging my phone in the cool of the morning. Outside temperatures are 8-12 degrees Celcius this time of year, and I can easily plop my phone between the window and screen while charging.
What is a bigger contributor, temperature while charging or staying within 25% to 75% charged? I try to keep my phone between those limits as measured by the phone itself, as I don’t have access to the battery voltage. Any idea how the numbers on battery U compare to what a phone tells you?
I have looked at battery university, and the famous charts of number of charge cycles vs depth of discharge. 20% depth of discharge gets a whopping 2000 cycles, but this is really equivalent to 400 cycles at 100% depth of discharge, so why bother using only 20% of the battery and charging constantly. Likely to wear out the connector instead, and needing a new phone anyway.
To summarize, curious to hear inputs on keeping a phone cool while charging at 1C rate to offset any degradation that could be caused by charging at 1C rate.
