Edit: Thanks for the info! Will make sure it’s not charging at too high a current, there is a mA display.
I have a battery charger that lists many different sizes of li-ion batteries: 10440, 16340, 17335, 18490, 18650, 26650. It’s listed as compatible with Li-Ion and LiFePO4.
If I get a light that uses 14500 Li-ion batteries, would that be compatible with this charger, even though 14500 isn’t specifically listed? Physically, it would fit in the spring loaded slot because there’s so much travel. Are all Li-Ion battery sizes the same chemistry, so the overcharge voltage would be the same and charging parameters are also the same? It seems to be from my research, but maybe there’s other reasons I don’t know about.
