Hey guys!
I just recieved my Intellicharge i4 V2 charger and was wondering if its safe to charge my Trustfire flames and KeepPower 14500 battaries using that charger?
Or i am better off charging all my 14500 cells on my Trustfire TR001 charger?
Thanks for the replies.
I currently have my Trustfire Flames in Slots 1 and 3 and my Keeppowers in Slots 2 and 4.
When checking the current its showing 750A on each slot ><
not sure if i am measuring correctly (using INNOVA 3320)
I think they meant to use 1/3 or 2/4 for charging 2 batteries at a time. If you are doing 4, put the 2 TFs in bays 1/2 and the KPs in 3/4. It cuts the charging voltage in half when you use 2 bays together.
Hmmm Using the Innova 3320 Multimeter i get 750A reading from all slots while having both trustfires on slots 1 and 2 and both keeppowers on slots 3 and 4
Am measuring it by having the Red Lead into the DC10A port and the Black Lead into the COM port, and having the switch on DC10A
I re-read the review by HKJ - take a look at his response to a question by Garry. Not truly cutting the current in half, but the time. Also, I was mistaken, 1/3 is one channel, 2/4 is the other. I should know better than to give advice on electronics.
