so i was drinking last night and kind of added stuff randomly in a mess… so sober me is going to come back and put it all somewhat neatly here in the first post
heres whats done:
- obviously, the tower was chopped off, and a heatsink made to fit.
- tube was bored and chopped to accept a 26650
- tailcap spring chopped and put inside tailcap to get it a little shorter.
- head end of battery tube was also chopped to get the head down closer to the switch
- its got an xml2 (u2 i think) and a custom programmed nanj driver @ 3.5a.
oh… and a ar lens too… i think thats it
here is the heat sink, driver and xml2 on the sinkpad waiting to dry
now a head on shot of that xml2 in the trimmed down mag reflector. i may be changing this out at a later time. thinking about an aluminium (for my foreign friends) orange peel one
and here is a shot of it next to an ordinary blue 2d LED maglite. you can tell this 26650 mag is not your typical blue mag. from my understanding, there was a batch of c cell mags that the blue anno had a purplish tint to it, and i was lucky enough to find one for a good price (thanks allthumbs!)
that is all for now. i could not for the life of me get the driver to solder to the heat sink. i will end up using some adhesive to keep it in.
and i will also need to get the driver soldered to the switch, which i think will require removing the c ring, and pulling the switch out of the head end.
other than that, thanks vestureofblood for the fine machining work.
update:
needed to do something else with it since the stock reflector would not work with the 20mm sinkpad. so i ordered up a new one from dx
http://dx.com/p/sst-50-smooth-aluminum-reflector-5-1cm-diameter-47997
after about a crap ton of filing (from 51mm to a little under 49mm) i got this bad boy to fit. and since the xml/xre plastic cetering disks (dont know the correct term) would not fit on the xml2, i had to get crafty. i coated the bottom of the reflector with electrical tape 8)
now to the testing
did some runs on the lux meter. now my lux meter reads my ea4w consistently at 17300-17400 cd.
i took my readings on the x10 setting
2m = 980 = 39200@1m
3m = 422 = 37980@1m
think xml in a c8 beam profile. almost the same size hot spot and spill size.
with my trusty new sanyo 1500s, im reading just over 3a at the tail now also. need some 26650s
thats all for now. sometime i got to upload some more pics and clean this post up a bit… someday
