Closed
OK here is the deal
This is meant for folks who can use them.
FYI these are NOT MR16 bulbs these are big long bulbs. Great for use in kitchens (but you need to plan or confirm they will fit) could certainly work in Baths also (same caveat), lets make sure what I am sending is what your expecting (remember the #2 goal here is to get them used, not just to sit at a new address) thank you again
Sending them to folks who “plan” on flipping them (because these are very expensive lights) is NOT the reason I am making the offer.
I wanted to give something back to BLF at large. I have been trying to sell them and I can tell you that the world does not get “PAR 38” bulbs especially ones with messy water damaged boxes. So if you don’t know what these are, but figure you can always throw them out (your missing the point) and you may want to save your money (and my time) shipping to just throw them out later. (not trying to sound harsh, but seeking to be clear)
Brand new
SP38G-18-36D-930-03
AND/OR
SP38G-18-25D-930-03
aka 3000k 95CRI lights
Expect factory box to be water damaged/(will remove from box and pack loose with padding and lid from box) each But has good intact labels so don’t worry about confusion. They have been 100% tested and are fine (as the bulbs are water proof) but no good for retail sale
Trying to juggle to fill every ones order. It looks like shipping is $20 per LG Flat rate USPS box (I just want them gone)
(open to shipping any odd quantities) The master shipping cases dissolved first, so I’m planning on shipping “smaller amounts” USPS medium or large flat rate boxes, still working out qty per. And/or UPS for larger qty (would like to serve as many folks as possible but #1 objective is to just make them disappear.
Just so you know they way I tested them is I bought Cheap GU24 to E26/7 adapters for a $1-$2 each so (adapters not included) then these can be used in “normal bulb sockets” That is how I tested them. But allow for a 5 inch long bulbs plus adapter if used and a 5 inch wide bulb so some fixtures will be too small. For example not good with lamps with shades (true, but LOL).
Bulbs will be weighted and prioritized in order of posted responses (below)/finalized count, acceptable degree spec, address and payment also matter. Will try to stay with first complete order first served. (“cases” no longer available, all orders on an individual basis. actual project size matters).
Please include quantity desired (meaning count your fixtures or project plan for total used) and preferred beam width (and also if beam width is a deal breaker) in PM, will respond to each member separately.
Will close or remove posting when out of stock. So as long as you see the ad I am still making orders.
If you haven’t/cant wire your project for GU24 you can still use these but they need an adapter to fit in normal sockets (adapter shown below)
