closed
They are soooo cheap brand new. Why not just buy some new ones and avoid the hassle?
Well tell u the truth I never owned 14500 so what are good and bad ? I don’t want real cheap china junk lol
I believe TrustFire 14500 cells were pretty good:
http://www.fasttech.com/products/1181000
Here’s HKJ’s review:
Ill check into those since they do ship fast ![]()
I converted my mini mag into a thrower with a cree ez900 led looking to see if these two 14500 can power my 7135 driver, if not ill use my 3aa host
I have 2 ultrafire flames 14500’s, don’t have the equipment to test them but I’m very satisfied with them.
I have a bunch of new ones still in their plastic. I sent you a PM.
No, the 7135 based drivers can old handle up to 6 volts. You will just kill the driver, you could use a single 14500 and a spacer.
Pm sent
Thanks scaru ill have it cut down, might look better ![]()
http://goinggear.com/flashlights/batteries/eagletac-protected-14500-750-mah-li-ion-rechargeable-battery.html (sent by Yahoo! Toolbar)
I use these as I have found they are right at the size of a AA as some others are longer and do not work in some of my lights.
Efest has some decent 14500’s as well as 14650’s both on eBay. Cut down Minimag looks great with either but the 14650’s give 20% more run time.
14650 would be good for runtime I never considered them
A bit more secure in the holster, too.
Ill check the forum to see where is the best to buy from
Mine are Efest imr purchased on eBay. Search 14650 lithium. The 10440’s I’ve purchased outrun the protected trustfires I’ve used.
The 10440’s are to small though, ill just buy from ebay or do lil searching here and see if there is a best place to buy
I was just using them as an example comparing same sizes. The efest cells were better, higher current, cells.
i bough a pair off ebay……thanks guys for helping
