Hi,
Has anyone used/worked with this driver from CNQ:
http://www.cnqualitygoods.com/goods.php?id=1391
“Hi current 20mm 3xLED in series 3-mode Torch Circuit Driver”
The specs are:
I want to drive this 3up, with Luxeon emitters:
http://www.ledsupply.com/07007-pw740-l.php
using 2 Li-ion batteries, and it seems like this should be correct, since it outputs 1000 mA (per the spec), as long as it can boost the 2 Li-ion voltage to 9V?
I have a couple of these incoming, but was curious if anyone had tried this driver?
Thanks,
Jim
P.S. I don’t mind the strobe mode, so no need to comment on that :)…
P.P.S. I had already emailed RIC, asking about this, but he hasn’t responded, so I went ahead and order a couple of them to test.
