TK, think it would be easy enough to post it down at the bottom where user photos go. You could review it to insert the text instructions.
-Arrg-just noticed another change to get done on my tattoo.
Yes, it would be much better as a downloadable PDF, done by members. It it is up to the manufacturer, we will end up with a translated, un-understandable mess.
Anyone remember the motherboard manuals of 15-20 years ago? One could only rely on the pictures, because the translated English was unintelligible. We should give thanks that the ones today are very good.
I read through the first post and did not see an update on the proposed $22-$23 cost. Is there an updated cost figure now? I’ll be interested in 1 model in CW.
Thanks! Corrected. Can't say about outside of the US but at $8 for the BD better off to get the newer versions from Richard or Calvin. He2's still well worth it.
Must be 3A because I could never find a 2D anywhere. 2D must be rare or it’s the the red headed stepchild of a tint. If it is a 2D tint, where did you ever find it?
3A isn’t a bad tint. It looks way better than 3C to me. I wanted to try out the 4D tint too, but they got sold out.
Same UI ???!!! You mean there is no difference whether mode memory is on or off?
1. With mode memory off, you turn off in Turbo. At what mode does it come on?
2. With mode memory on, you turn off in Turbo. At what mode does it come on?
What is the “what” that is done the same way?
What you mean by “change from 4 to 7”? What’s “4” and “7”?
The same way almost every other mode memory works.
With memory on, it comes back on whatever mode you turned it off.
With memory off, it comes on the lowest mode
You can choose whether you want 4 modes or 7 modes by pressing the button repeatedly and entering configuration mode. You turn memory on/off in config mode also.
All of this was discussed, it seems like you need to read some more
