Code now public! BLF A6 FET+7135 Light. Short 18350 tubes and Unanodized Lights Available
[quote=bugsy36]
* All updates to OP are at the end of this post but ABOVE the interest list.
I like easy to carry tube lights. One of my favorites is the Eagle Eye. Eagle Eye has a new model designated the A6 and comes with a an XPL emitter, 2.8A 4-mode driver. See here at Banggood
Most of us already know the Eagle Eye quality from the X6 and my EE F30 has treated me very well. For me it is natural to want this EE A6. It is a tube light like the F30 with a Xiaozhi styled tube/barrel.
What I am proposing, if it can be done, is to have Eagle Eye and Banggood manufacture us a BLF Edition with a A17DD-SO8 driver
(designed by our own Wight). The idea behind using that driver is that it can drop right in because it is single-sided and we can eliminate the moon vs amps debate as well as it will give the many the ability to change mode levels to suit.
Proposed specs
  • XPL emitter in CW and NW tint
  • Copper mcpcb
  • A17DD-SO8 driver (already approved by wight)
  • 7 modes with stepdown at high (no blinky) and of course the lowest possible low
  • AR Glass (I remember reading that it already comes with it but I cannot find that reference again)
  • BLF-SE engraving (subject to Kronos’ approval)
  • Guessing that approximate cost would be $22-$23
Unfortunately to pull this off would not be quite as easy as it sounds. In order to achieve this we would need:
  • Quantity of 200 to get the engraving (probably not so hard)
  • Quantity of 500 to get the copper without increasing cost (500 is the minimum run Maxtoch will do for mcpcb and if true to form this unit should have 16mm mcpcb). Less is possible but cost will increase.
My math that inspired me to attempt this group buy:
BLF 17DD Diver from RMM w/ options ~$14.25
Noctigon 16mm Driver from RMM ~$1.99
Subtotal parts 16.24 plus shipping plus cost of flashlight (EE A6 ~$19) = $35.24 +/- vs GB of $22-$23 (or even less if we can get the same success of the X6-SE)
To me that is a huge savings.
UPDATES:
12/31/14: Was informed that EE WILL indeed use the A17DD-SO8 driver if we can get enough interest to move this thing forward. Also have lights on the way to test with the A17DD-SO8 driver so everybody can see what the driver truly is capable of. FYI - I know it sounds like I am hyping this driver but I would not be so excited about this driver of I did not think it or see that it was capable.
1/6/15: Stock lights are on the way to be modified with Wight’s driver so that this light/driver combination can be tested and demonstrated. The actual production run (light and driver) will be by EE. The A17DD-SO8 driver will not be manufactured for sale separately nor does anybody have permission to do so except by individuals for personal use. (The A17DD-SO8 driver will be available in the future from RMM’s store: http://www.mtnelectronics.com/)
I would really like to know if this is possible and if there is any interest please post here.
1/7/15: There are 4 main things that separate this from a stock Eagle Eye A6
  • BLF Logo
  • The A17DD-SO8 driver
  • Copper for the emitter
  • User’s ability to flash firmware
1/20/15: Samples arriving. Preliminary results are good. See post #304 and beyond for DBCstm’s tests. The below numbers are with no spring bypasses, just the A17DD-SO8 driver and copper star.
Stock numbers with factory driver
Numbers with A17DD-SO8 driver over 5 amps!!
1/26/15: I have been working like crazy so I did not have the opportunity to swap the driver and the emitter in my sample until tonight.
Wow! Even with a laptop pull this light blows everything away!!Throw a 25R in there and this thing shoots the moon
The beam profile, even though it is subjective to the individual, is fantastic. Not a flood but definitely a large spot with a nice spill. Sort of what I would like to see possible but not with a triple. It is not a thrower like the LS D80 Kronos is working on but I never expected it to be either. I can still light things up several houses away :slight_smile:
The Xiaozhi styled tube/barrel feels real good in the hand and something else that is welcomed is the deep scallops that allow you to get to the switch (sometimes I have to wear heavier mechanics gloves at work vs surgical styled gloves)…and this thing still tail stands.
The driver, as it is and I requested be setup at the moment, has 7 nicely spaced levels that run from the lowest low (battery dependent) to all out (again battery dependent). You can refer to the OP for the link to Dale’s numbers. I have yet had the opportunity to take my measurements but just by the output visible to the eye Dale’s numbers are spot on.
Where we currently stand on progress is as follows:
  • Waiting on samples for others (aside from Dale and myself) that got tied up in shipping :frowning:
  • Have another person on the team that is experimenting with code and UI’s and attempting to get the most reliable low (or moon) possible
  • When the UI is finalized by the team we will ask Banggood to manufacture samples there and send them (they have a holiday coming so things will get slow on communication)
Everything so far is going as planned and expected and very well may end being not only a great light in BLF tradition but also the most versatile light available. :slight_smile: Many many thanks to the team working hard on this behind the scenes, and of course all BLF’ers for the support!
2/2/15: 303 units!!!
As mentioned before, the review team is working on the A17DD-SO8+1 7135 driver and its firmware and it is sounding very promising :slight_smile: After PM’ing with Banggood tonight we can all expect to see production samples after the Chinese holiday.
Interest List:
  1. Bugsy36
  2. Bugsy36
  3. Bugsy36
  4. Bugsy36
  5. Wedlpine CW
  6. Wedlpine NW
  7. Racoon City
  8. Fireblade893
  9. Ricflair
  10. Beachlogger CW
  11. Beachlogger NW
  12. Dangerous NW
  13. Charga CW
  14. Calmaja NW
  15. Cliwilnew NW
  16. Werner
  17. Adoby NW
  18. Danielrhall NW
  19. DanielM NW
  20. Nguyen
  21. Nguyen
  22. TyBreaker
  23. TyBreaker
  24. Keengeorge CW
  25. Keengeorge CW
  26. Keengeorge NW
  27. Keengeorge NW
  28. Netprince NW
  29. Netprince NW
  30. The Burgh NW
  31. Patrickbateman NW
  32. Nisse NW
  33. Downlinx
  34. Adnj
  35. Adnj
  36. Steve-o NW
  37. Jmpaul320 NW
  38. Aslpg NW
  39. Aslpg NW
  40. Raven38571
  41. Sonofspectrum
  42. Martini
  43. Zelee NW
  44. Allthumbs NW
  45. DavidEF NW
  46. DavidEF CW
  47. Muto CW
  48. Muto NW
  49. Tryps NW
  50. Tristanxoxo NW
  51. D10ten NW
  52. M78 NW
  53. Kronological NW
  54. Kronological NW
  55. Kodachrome40 NW
  56. Viperbart CW
  57. Viperbart NW
  58. Absalom NW
  59. Dthoang NW
  60. Racer86 NW
  61. Kst NW
  62. Ncice5
  63. Syracuse NW
  64. Blueb8llz CW
  65. Blueb8llz CW
  66. Blueb8llz NW
  67. Blueb8llz NW
  68. B42 NW
  69. Southland
  70. Southland
  71. Ryansoh3 NW
  72. Prisma NW
  73. Gamezawy
  74. Stittville Ed NW
  75. Stittville Ed CW
  76. Bill 63 NW
  77. Xjsnake NW
  78. Xjsnake NW
  79. Clagged NW
  80. Billy X NW
  81. Kawiboy1428
  82. Kawiboy1428
  83. Kawiboy1428
  84. Kawiboy1428
  85. Nightspy CW
  86. Dodo NW
  87. MRsDNF NW
  88. Chazzy NW
  89. Otanacious NW
  90. Otanacious CW
  91. Freeme CW
  92. Freeme NW
  93. Qandeel NW
  94. Level NW
  95. Level NW
  96. James B NW
  97. Cajampa NW
  98. Gerrit CW
  99. Glowz NW
  100. Max CW
  101. Flomotion CW
  102. Flomotion NW
  103. BorisBar NW
  104. Hank NW
  105. ChibiM NW
  106. Minimoke NW
  107. Lite1000 NW
  108. Electricjelly NW
  109. Cone CW
  110. Cone CW
  111. Dondulah NW
  112. Dondulah NW
  113. Bigblockmopar CW
  114. Jim_r NW
  115. Ih8myx CW
  116. Ih8myx NW
  117. Krikstas NW
  118. 2 Dogs CW
  119. Dbss CW
  120. Dbss NW
  121. Jdunlap27284 CW
  122. Frankie Baby NW
  123. Boaz NW
  124. Boaz NW
  125. Boaz NW
  126. Boaz NW/(WW??)
  127. Cabfrank CW
  128. Alexey602 NW
  129. Meteorxs NW
  130. Scotlarock CW
  131. Scotlarock NW
  132. H-man NW
  133. Siata94 NW
  134. Embed NW
  135. Chicken Drumstick NW
  136. Randolph CW
  137. Newland CW
  138. Lawenforcementguy CW
  139. Joat NP
  140. Warhawk-AVG NW
  141. Warhawk-AVG NW
  142. Wdkingery NW
  143. Themaindude NW
  144. Themaindude NW
  145. Yourid NW
  146. Yourid NW
  147. Yourid CW
  148. Yourid CW
  149. Aardvark NW
  150. Sarge930 CW
  151. Sarge930 NW
  152. G60
  153. Chouster CW
  154. Albertopnp NW
  155. Will Manners NW
  156. Gj NW
  157. Gj NW
  158. Retiro675 NW
  159. Ryanferg NW
  160. Sandanbob NW
  161. Khas NW
  162. Khas NW
  163. Gleamer NW
  164. Trigger619 NW
  165. Trigger619 NW
  166. Trigger619 CW
  167. Trigger619 CW
  168. Nitro NW
  169. Msg1285 NW
  170. Rova2014 NW
  171. Saigon CW
  172. Sungsmith NW
  173. Spamman NW
  174. Xtrocity NW
  175. Zoom Zoom CW
  176. Bakalakos
  177. Wedlpine CW
  178. Wedlpine NW
  179. Djozz NW
  180. Moridin NW
  181. Bigblockmopar NW
  182. Calmaja NP
  183. Ilovejesuschrist NW
  184. Ilovejesuschrist NW
  185. Ilovejesuschrist NW
  186. Ilovejesuschrist CW
  187. SmokinH CW
  188. SmokinH NW
  189. Akoposilester NW
  190. Akoposilester CW
  191. Thebaum CW
  192. Jkbam NW
  193. Dbss NW
  194. Dbss CW
  195. Jensa41 CW
  196. Jensa41 CW
  197. Jensa41 NW
  198. Jensa41 NW
  199. Meyer NW
  200. Netjrb NW
  201. Netjrb NW
  202. Netjrb NW
  203. Netjrb NW
  204. Ger-slash CW
  205. Ger-slash NW
  206. Ray-o-light NW
  207. Can NW
  208. V.chiu NW
  209. Dthoang CW
  210. Tete NW
  211. Tete NW
  212. Fmc NW
  213. Megalodon NW
  214. Morris8809 NW
  215. Morris8809 NW
  216. Thebo NW
  217. Geo1952@gmail.com NW
  218. Gleamer NW
  219. Infinite NW
  220. Hannoveraner NW
  221. Koyotee NW
  222. Koyotee NW
  223. Sparkey762 CW
  224. Sparkey762 CW
  225. Sparkey762 NW
  226. Sparkey762 NW
  227. Hestbech NW
  228. Melvin CW
  229. Johnnydoe NW
  230. Absalom NW
  231. Absalom NW
  232. Absalom NW
  233. Absalom NW
  234. Absalom NW
  235. Absalom NW
  236. Absalom NW
  237. Absalom NW
  238. Absalom NW
  239. Absalom NW
  240. Peetz NW
  241. Peetz NW
  242. Flashination NW
  243. Bdiddle CW
  244. Bdiddle CW
  245. Bdiddle NW
  246. Bdiddle NW
  247. Scuffy NW
  248. Mrsdnf NW
  249. Cabfrank NW
  250. Mfruit CW
  251. Lionheart_2281 CW
  252. Igor0203 NW
  253. Drjones NW
  254. Aardvark NW
  255. I.c.bacon NW
  256. Mg NW
  257. Plumrt CW
  258. Plumrt NW
  259. Plumrt NW
  260. C-channel NW
  261. C-channel NW
  262. Trigger619 CW
  263. Gunga NW
  264. Cellguy NW
  265. Cellguy CW
  266. Zipelgas NW
  267. Richnpc NW
  268. Trigger619 CW
  269. Trigger619 CW
  270. Docfar NW
  271. Docfar CW
  272. Urausb CW
  273. Sxv NW
  274. Sxv NW
  275. Sxv NW
  276. Lite1000 NW
  277. Ronmuller NW
  278. Luckyseven NP
  279. Eigenmeat NW
  280. Shuggarush NW
  281. Reavenger CW
  282. 1afc NW
  283. Eroheam NW
  284. Cbrake10 NW
  285. Cbrake10 NW
  286. Sigshooter NW
  287. Gunga NW
  288. Daylighter CW
  289. Daylighter NW
  290. Nbabu NW
  291. Mhanlen NW
  292. Seben CW
  293. Seben NW
  294. Scdaf NW
  295. DavidEF CW
  296. DavidEF NW
  297. Processengr NW
  298. Borisbar NW
  299. Billy x CW
  300. Tryps NW
  301. Tryps NW
  302. Mike72 NW
  303. Mike72 NW
  304. Mxdan NW
  305. Joat NP
  306. Joat NP
  307. Angel Martinez NW
  308. Saigon NW
  309. Halo NW
  310. WhitedragonBC NW
  311. Siata94 NW
  312. Hagg911 CW
  313. Hagg911 CW
  314. Fantomr NW
  315. Uqs1000 CW
  316. Uqs1000 NW
  317. Tapir CW
  318. Kodachrome40 CW
  319. Logindetails NW
  320. Logindetails CW
  321. Geo1952@gmail.com CW
  322. Plato NW
  323. Cliwilnew NW
  324. Cliwilnew CW
  325. Frankie Baby NW
  326. Frankie Baby CW
  327. Ray-o-light NW
  328. Kurt_norway CW
  329. Kurt_norway CW
  330. M4d m4x NW
  331. Presterjohn NW
  332. Seepeli NW
  333. Penumbra CW
  334. Hell2pay NW
  335. Hell2pay NW
  336. Hell2pay NW
  337. Hell2pay NW
  338. Rolz NW
  339. Zeremefico NW
  340. Prodal NW
  341. Cybertek NW
  342. Ronmuller NW
  343. Beam0 NW
  344. Will Manners CW
  345. Flomotion NW
  346. One41 CW
  347. One41 CW
  348. Richnpc CW
  349. Xp-r NW
  350. Xp-r NW
  351. Skippey NW
  352. Southcovekayak NW
  353. Southcovekayak CW
  354. M4d m4x CW
  355. Will Manners NW
  356. Will Manners CW
  357. Devman NW
  358. Devman CW
  359. Mfruit NW
  360. Caffeine_addict NW
  361. Caffeine_addict NW
  362. Ramblings CW
  363. Ramblings NW
  364. Streamer NW
  365. Pokemonrules NW
  366. G_sintornillos NW
  367. Cnrffl1 NW
  368. Seasam NW
  369. G0ose CW
  370. Xp-r NW
  371. Henk4u CW
  372. Hairy_Steve NW
  373. Bdivi NW
  374. Carmantl NW
  375. Carmantl CW
  376. Johnlate NW
